mr mugello wrote:Just replaced the two front hub oil seals. Hub was spinning freely on the spindle like a roulette wheel before I split for painting. Would the fitment of new seals cause tightness on the hub spindle ? Thanks
mr mugello wrote:Just thinking back. The seals don't come in contact with the spindle, metal spacers fitted in the centres. Fresh grease packed around bearings might be simply causing problem of stiffness.
mr mugello wrote:Yes sorry. I realise the top hat outside collar is clamped up with spindle. Is it also possible you can punch the inside seal in too much which will push the bearing in further causing it to rub pressure on the long central spacer ?
Users browsing this forum: dave81 and 61 guests
