1961 LI125 S2
1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:20 pm
Its been a year since I started this project. Nice to look back and see where she has come from.
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:22 pm
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:28 pm
she was in a bad stare of disrepair. Full nut and bolt restoration was the only option.
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:31 pm
New rear struts fitted. Damper brackets fitted to the forks.
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:33 pm
50 years of Italian dirt inside the headset..
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:35 pm
the leg shields had seen much better days
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:36 pm
the other side
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:43 pm
dry build before the powder coating on the frame, tank, tool box, rear mudgard, front inner mudgard, forks, BMG airbox, seat frames, ect.
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:46 pm
top tip. Always photo the wiring connections (after a little cleaning)
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:48 pm
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 7:54 pm
I got a little carries away once the powder coating came back. Along with all the profeshionally polished parts. the rebuild started in earnest.
New Beedspeed Loom, Teflon cables. 6mm foam rubber added to all connection surfaces to stop any vibrations.
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Sun Feb 12, 2017 8:01 pm
new rebuilt SIL engine with a 175cc stage 4 top end, MEC crank and 30mm Deli. New seals, bearings Targa line rear damper. i didnt like the black chain case, so this got removed and sent for polishing. I still have the original engine and will rebuild at a later date.
Watfordwhite
Re: 1961 LI125 S2
Postby Phil D » Sun Feb 12, 2017 8:11 pm
Very nice.
Up the "peacocks " ;)
Phil D
Re: 1961 LI125 S2
Postby Rich Oswald » Sun Feb 12, 2017 9:05 pm
Very nice, MOT.
Re: 1961 LI125 S2
Postby Phil D » Sun Feb 12, 2017 9:06 pm
Phil D
Re: 1961 LI125 S2
Postby Kev » Sun Feb 12, 2017 11:18 pm
Very impressive work :D
Kev
Re: 1961 LI125 S2
Postby Watfordwhite » Mon Feb 13, 2017 2:18 pm
Now with the polished chain case and new BMG clubman
Watfordwhite
Re: 1961 LI125 S2
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Mon Feb 13, 2017 2:19 pm
Final dry build before wet painting
Watfordwhite
Re: 1961 LI125 S2
Postby Watfordwhite » Mon Feb 13, 2017 2:21 pm
Watfordwhite
Users browsing this forum: No registered users and 92 guests
