Rich Oswald wrote:Is it a 225 Classic or 225 Race? Imo that set up will be fine for the classic but if it's a race version then I don't think you will get the best from it with the 48mm Clubman.
Stevie W wrote:Rich Oswald wrote:Is it a 225 Classic or 225 Race? Imo that set up will be fine for the classic but if it's a race version then I don't think you will get the best from it with the 48mm Clubman.
There is no classic rapido 225 only a race kit but it does have a choice of pistons. I chose the skirted (cheaper one) which changes the port timing slightly making it easier to set up.
Stevie W wrote:After trying to keep up with my friends TS1 I decided that I need to give my Indian GP200 a bit of a boost. I don't want to go racing about but want to just have more torque and a bit more top end. To achieve this I have bought the following Rapido 225 kit, AF 48mm clubman exhaust, 30mm Dellorto phbh along with a Tameni crank , Koyo bearings and Rolf seals.
What's the consensus on this setup and are there any tips which might get the best out of it.
Meds wrote:Interesting comment about the long stroke crank,How would you set it up with the long stroke crank?
I was thinking about a 60x110 rod in mine which means 4mm longer at TDC and 2mm longer at BDC (over a standard 58x107).
Meds wrote:I dont know much about this so stating the obvious is a big help .
Im only playing with this to get an Idea what needs doing and wheather I want to.
Fitting a small packer (say 1.5mm) to reduce the exhaust and transfer timing means increasing the head gasket to 2.5mm, which seems a lot to me but may be perfectly acceptable?
inlet duration isnt a problem as I have a reed fitted with a TS1 piston, this cleaned up the lumpy bottom end really well
Meds wrote:LTH reed, cost me 4 MPH top end, made the scooter much more rideable round town.
I have a PM25 on it at present so it great on A roads where we can keep up revs but not great up hills
On the plus side fuel consumption is great.
I'm looking at trying to smooth it all out and I have a bit of a plan.
1. Return to a low/mid power exhaust
2. Tame the port timings ( it would have been simpler buying a less aggressively tuned barrel, but I have it now)
As to the packers, my calculations are as follows, taking the datum as the crank center as this is a known fixed point ( and removes the unknown in casing machining) to the top of the piston
58x107, 39mm piston. 60x110,39mm piston
TDC: 107+39 +29 =175mm. 110+39+30 = 179mm difference 4mm (3mm extra rod length+1mm extra crank throw)
BDC: 107+39-29 =117mm. 110+39-30= 119mm difference 2mm (3mm extra rod length- 1mm extra crank throw )
Based on my current set up as the start point, to get the piston at the same position WRT to the ports I need to
lift the barrel 2mm at BDC (using a packer)
At TDC I would need a further 2mm
So if I wanted to reduce the port timings, I would have to have to move the piston up the cylinder at BDC by reducing the size of the base packer.
As the extra length required at TDC is fixed at 4mm, what ever I take off the bottom I need to add to the top maintaining the 4mm.
Alternatively the use of a 58/110 Set up
TDC 39+110+29=178mm
BDC 39+110+29= 120 mm
seems much gentler method and allows a bit more scope to reduce the size of the base packer, but there must be a down side with the 58/110 rod?
I have tried to show all of my assumptions, reasoning and calcs to identify if there is a flaw in my logic
what I need is to do is work out what can be done reasonably, my biggest issue is having a big head gasket.
Or do I just live with it and enjoy the quirks.
Meds wrote:Thanks for that.
I agree it needs to be built to set it up correctly and allow for all of the tolerances,
now I know it's feasible and my calcs are ok a decent starting position.
Now comes the hard bit.
Setting what timing I need then making it happen.
I might go for a 58/110 crank as it seems to give more scope on the bottom with less issues around the head.
I will probably get it ball park using packers and gaskets then sort it out next winter to optimise
