missing lynx wrote:have you converted to dc?
P D: SC Chester wrote:My question is: will the rest of the power come once the scoot is running, or do,I need to do a bit more fiddling?.
missing lynx wrote:so have you converted your stator? also to run all the things you say you want to you will need a high watt stator your indicators will work best on DC and will need to be fed seprately from your light circuit or you lights will flicker when you indicate I use led bulbs in my indicators and have found these work best on a full DC system
