Helicoil
Helicoil
Postby Seamus murphy » Wed Feb 01, 2017 7:39 am
What size helicoil for a barrel stud (what depth can you get the holes are 17mm)
Seamus murphy
Re: Helicoil
Postby Warkton Tornado No.1 » Wed Feb 01, 2017 1:11 pm
The length of installed Helicoils is based upon the diameter ‘D’
Therefore an M8 x 1.25 x 2D has an installed length of 2 x D = 16 mm
The subject of cylinder studs was recently discussed on this Forum, specifically ways in which the strength of the stud/hole relationship may best be optimised.
Re: Helicoil
Postby Seamus murphy » Fri Feb 03, 2017 6:19 pm
What was the thread pal l cant find it
What is the best way to fix
Helicoil
Timesert
Other
Seamus murphy
Re: Helicoil
Postby Knowledge » Fri Feb 03, 2017 7:41 pm
Barrel studs are M8 (8mm)
Re: Helicoil
Postby Jim Rose » Sat Feb 04, 2017 1:50 pm
Timesert is better if you can get them the right size etc
Jim Rose
Re: Helicoil
Postby Warkton Tornado No.1 » Sat Feb 04, 2017 2:20 pm
Post by Seamus murphy » Fri Feb 03, 2017 6:19 pm
Helicoil
Timesert
Other
Post by Jim Rose » Sat Feb 04, 2017 1:50 pm
Lambretta cylinder studs are M8 ‘course’ which is Metric Ø8 mm with a thread pitch of 1.25 mm
Although Helicoil (wire thread inserts) are used extensively to repair stripped threads, the main use is for their installation during the manufacturing process by many manufacturers. Think Rolls-Royce, Boeing etc.
Fitted correctly, they are a superb product that increase the strength of the resultant thread, were it to be left as, say, aluminium alloy.
Any thread repair should be carried out with due thought to the remaining material left around the insert & the likelihood that there may be need for subsequent repairs.
Personally, I have the resources for Helicoiling & Keensert repairs.
However, for reasons explained, I would use Helicoils in the first instance ;)
Re: Helicoil
Postby Seamus murphy » Sun Feb 05, 2017 12:26 am
Thanks for replying l know there will be a load of ways to do the repair but what l was trying to find out was one that been proven on barrel studs. Im going with helicoils and have found someone who does it for a living and has for the last 20 plus years. The threads arnt stripped just sloppy so hopefully l wont be following this thread up with a how do you repair helicoils. Thanks again
Seamus murphy
Users browsing this forum: No registered users and 154 guests
