Basically, having managed to find time to get the front strut welded, 20 mins with the Rust Remover, 10 mins spraying ACF50 everywhere and then whack the engine in, this is where I'm at
Storkfoot wrote:Struggling to find the time to make any progress at present but that should change in a few weeks, I hope.
The shock is a Gaz one. I tried it on my GP but didn't like it, the spring is too weak and there's only a very limited amount of preload you can get on it. If I hadn't scratched it trying to get more pre load, I'd have sent it back.
Knowledge wrote:Storkfoot wrote:Struggling to find the time to make any progress at present but that should change in a few weeks, I hope.
Does the shock disassemble? It might take a heavier spring, like the ones used on the R1 conversions. Just an idea for later....
Keep the info coming Paul. Loving your work, man
Knowledge wrote:Will it be too wide? Reach for a panel Paul. It will be a moment of truth.
Users browsing this forum: Baidu [Spider] and 74 guests
