Oil
Oil
Postby P D: SC Chester » Thu Feb 02, 2017 12:31 am
I was filling a dry built engine and put 0.7 of a litre in, which seems a lot, so,I undid the highest Allen key plug and let the oil drain until level. But the it only worked out at 0.4, what do you guys recommend ?
P D: SC Chester
Re: Oil
Postby Fast n Furious » Thu Feb 02, 2017 12:52 am
Is the engine in the scooter, on its stand and sat on level ground?
Is the rear shocker length shorter than normal?
Re: Oil
Postby Donnie » Thu Feb 02, 2017 1:54 am
always used 700 for a dry built engine, 500 for a wet engine. ie an oil change.
Donnie
Re: Oil
Postby MickYork » Thu Feb 02, 2017 7:58 am
Donnie wrote:always used 700 for a dry built engine, 500 for a wet engine. ie an oil change.
as above, think that's what Sticky's recommends.
Re: Oil
Postby Phil D » Thu Feb 02, 2017 8:34 am
I may be wrong but you've got to let everything get a coating of oil that's why 700 dry And 500 wet.
First fill on any Re -built motor always takes a bit more they usually recommend re-checking after a short run ,then it's got in all the nooks & crannies.
You may find you have to top up a little doing it that way.
Phil D
Re: Oil
Postby P D: SC Chester » Thu Feb 02, 2017 12:25 pm
Thanks guys
P D: SC Chester
Users browsing this forum: dave81 and 64 guests
