Li 150 1st gears
Li 150 1st gears
Postby coaster » Tue Aug 05, 2014 7:53 am
Hi, my kickstart has started slipping i.e. not engaging on the 1st gear. I haven't taken it apart yet but suspect that the kickstart shaft might have bent. It's an Italian Li150 box on a TS1 but tbh, it did miss sometimes when it was fitted to a muggy 186 leading me to consider that the 1st gear is also a bit worn. So I was wondering if anyone has any experience of the Indian loose gears sold on ebay? I know that ScootRs also sell them but their shipping costs are way too high.
Colin
Re: Li 150 1st gears
Postby Dimitrios_231 » Tue Aug 05, 2014 9:17 am
I have two spare NOS Spanish 150, 1st loose gears.50 teeth,same diameter as Italian Li 150.30 GBPs each,including postage to UK or 50 GBPs for both.
PM me if you are interested.
Dimitrios_231
Postby coaster » Tue Aug 05, 2014 4:05 pm
Thanks Demitrios 8-)
Postby torquewrench » Tue Aug 05, 2014 5:54 pm
coaster wrote:Thanks Demitrios 8-)
Spell his name correctly, and you might even get a discount. :mrgreen:
torquewrench
Postby Dimitrios_231 » Tue Aug 05, 2014 8:36 pm
Dimitrios_231
Postby coaster » Tue Aug 05, 2014 11:47 pm
:oops: :oops:
Postby Wack » Wed Aug 06, 2014 6:11 pm
Do you want to sell one?
Postby nickwill » Wed Aug 06, 2014 6:26 pm
Coaster,
Before replacing 1st gear bear in mind the teeth on the kickstart piston are generally softer than those on the gear itself, so likely to wear out first. I would assume that's how the system is supposed to work, ie replace piston periodically rather than mess up the gearbox, but I'm no expert. Guess you will find out when you take the sidecase off. Could be adjustment also if not the GP fixed ramp type.
nickwill
Postby coaster » Sat Aug 09, 2014 7:59 pm
Yes, I've got a replacement piston but it's always slipped and I'm failrly sure some of the pawls are chipped anyway
Postby byron » Thu Aug 14, 2014 9:56 pm
Colin, I have two 25litre oil drums, both overflowing with cogs and clusters, you are welcome to take a look.
if you sort some cogs out as you search, you can have one!
Peach & Cheggers did make a start last week, but they quickly got bored...
byron
Postby coaster » Thu Aug 14, 2014 10:01 pm
That's very kind of you Jarv but Dimitrios sorted me out a treat 8-) How's the LML doing, need any cash yet?
Postby byron » Thu Aug 14, 2014 10:05 pm
coaster wrote:That's very kind of you Jarv but Dimitrios sorted me out a treat 8-) How's the LML doing, need any cash yet?
my phone has been down... will get back to you friday. another dubious package from india has arrived...
byron
Postby coaster » Fri Aug 15, 2014 12:23 am
No worries Jarv I'll give you a buzz next week 8-)
Users browsing this forum: No registered users and 55 guests
