Warkton Tornado No.1 wrote: The tie-rod should then be refitted behind the caliper rather than as you have it.
corrado wrote:Warkton Tornado No.1 wrote: The tie-rod should then be refitted behind the caliper rather than as you have it.
Not if you use the existing tie bar as the caliper mounting plate is threaded and is in effect the "nut". Same goes for the clamp.
I sell these kit but I don't like those tie bars [basically a flat bar with a rubber washer] so change them for one that uses rose joints as Gaz has pictured. Also use longer bolts so I can fit a binx nut on the end for safety, [belt & braces].
a-teamlambretta wrote:yours looks wrong to me, whats that extra bit of plate behind the plate whet the caliper fits on ?? ,
corrado wrote:a-teamlambretta wrote:yours looks wrong to me, whats that extra bit of plate behind the plate whet the caliper fits on ?? ,
Phil D wrote:Just a thought wouldn't the Binx nuts be ideal for the exhaust flange .
Users browsing this forum: dave81 and 64 guests
