Unread postby ToBoldlyGo » Sun Jan 29, 2017 2:41 pm
Hi Adam.
Jetting seems to be there with a healthy colour on a B8 plug. It's a Scootopia fuel tap and there seems to be a decent flow through. But yes, it needs to come apart properly and the timing has got to be a suspect. Piston to bore tolerance, could be. Although it was remarkable for not even being marked after the first time.
CHRIS in MARGATE wrote:There was a slight clue in your first posting. You said it always managed hills under load without a hint of a problem but now it has heat seized it twice. So something has changed in the meantime. Anything ?
MickYork wrote:Too much Christmas pudding...........
Unread postby ToBoldlyGo » Sun Jan 29, 2017 7:27 pm
In August!
Re: Head cowling improvements
Postby Warkton Tornado No.1 » Mon Jan 16, 2017 9:15 pm
Postby Fast n Furious » Mon Jan 16, 2017 7:37 pm
Photographs mmmmm.
My camera makes pictures that are 5+Mb jpeg which are too big for posting I think. I need to find a way of condensing these into something more manageable. When I've figured that out I post some pics.
Dropbox is available free & a hassle free way of adding files, IMHO. (https://www.dropbox.com/en_GB/)
BTW, the longer response of yours (detailing your analytical approach to improving head cowlings) makes for excellent reading.....
Re: Heat Seize
Post by Fast n Furious » Mon Jan 30, 2017 2:48 am
All Lammy's require tuning in such a way that they don't produce too much piston heat as indicated by the advice above.
They also require an effective forced air cooling system that works properly irrespective of weather conditions.
Iron cylinders, lightweight heads and some piston makes are particularly susceptible to seizure due to poorly engineered cowlings.
ROClarke wrote:Could be a " Cold Seize".
Where do you keep your Scooter?
The answer is to thoroughly warm the engine before putting it under load
holty wrote:your problems could well be many of the things mentioned above, adam mentioned that your plug colour is only an indication of your mixture, and he is right, its not easy to read a plug, or to do a proper plug chop, you should simulate the conditions it siezed in,best plug chop is uphill full throttle and held there , your fuel mixture is the biggest cooling factor on your engine, too lean and your in trouble, hills put your engine under more load so you will open the throttle more to compensate, i would check your flow of fuel out of your fuel pipe first, then i would do a leakdown test, next strobe your timing, when all that is ok i would check the jetting, i normaly over jet a carb til it bogs on full throttle, then come down in size til it wont bog anymore and you should not have any more nipping up, you wont get max power this way but your engine will be safe at full throttle, i would also check and maybe increase pilot jet as well,
good luck,
holty
hullygully wrote:were you wringing its kneck up the hill/incline or just on half throttle?
when you say Scootopia carb is it a sh2/22 version?
how far into your ride was it?
& I prefer rice pudding.....
