5 pin rectifier
5 pin rectifier
Postby Marty ULC » Fri Jan 27, 2017 1:53 pm
Apologies if this has been done to death but I can't find an answer that I fully understand.
Don't confuse me with talk of full DC or wassel systems.
I simply want to know which regulator and where (apart from ebay) I can get one.
Which v*spa regulator is a direct swap for a BGM one to give me ac electrics with a DC trickle charge to top up a battery to run an sip speedo and charge a phone?
There appear to be more than one type of 5 pin.
Marty ULC
Re: 5 pin rectifier
Postby jonno » Fri Jan 27, 2017 5:24 pm
Beedspeed do them.
jonno
Re: 5 pin rectifier
Postby shane BBoys » Fri Jan 27, 2017 7:08 pm
Mod charger work great no battery required.
Cheers Shane
shane BBoys
Re: 5 pin rectifier
Postby mcbrid » Fri Jan 27, 2017 8:41 pm
My Modcharger blew up - fried anyway
Binned it
mcbrid
Re: 5 pin rectifier
Postby Timexit17 » Fri Mar 24, 2017 7:12 pm
Mine too -had 2 and every time I fit them they work OK, then when I actually go to use them 6 months later they're dead as a doornail.
I suspect they are simply not robust enough to cope.
Timexit17
Re: 5 pin rectifier
Postby Knowledge » Fri Mar 24, 2017 11:18 pm
Marty,
My recollection is that the five pin regulator/rectifier requires power from a battery to work. If your battery goes flat, it will not work and it will not charge your battery if it does not work.
The stator often needs to be re-wired, with two coils providing power to the lights (AC) and two coils dedicated to providing the DC pins.
This info may be a little out of date but it is why many people have opted for the simpler Wassel set-up, but I respect your choice to go this route.
Re: 5 pin rectifier
Postby Meds » Fri Mar 24, 2017 11:38 pm
Try Anthony Tambs on facebook, he does ac regulators with a DC output like the BGM ones
Meds
Re: 5 pin rectifier
Postby CHRIS in MARGATE » Sat Mar 25, 2017 8:16 am
Jumper a wire from AC lighting output on regulator to pin 4 and you will get your trickle charge from pin 5.
Re: 5 pin rectifier
Postby philcasino1973 » Sat Mar 25, 2017 11:00 am
deffo ask anthony tambs on facebook ...top quality products at a good price and will advise on what you need phil
philcasino1973
Users browsing this forum: Google [Bot] and 62 guests
