by Leotech » Sat Jan 21, 2017 6:37 pm
Just built a new motor for the season and every time I select third gear the dogs slip around 2 or 3 times until it settles, I'm thinking I need a new third gear as the other 3 gears are fine. Do you agree? or is it worth trying a new spring first? Im not leathering it, I'm only just being gentle as its getting run in.
Has anyone got a TV175 / SX200 third gear they would sell thats in good condition or even better new?
Leotech
by Leotech » Sun Jan 22, 2017 11:08 am
I did think that! but I always use the original manual whenever I fit a gearbox. Its one if those things I never try to remember.
I intend to check it.
Leotech
by WXboy64 » Thu Jan 26, 2017 4:37 pm
Is this a known working box?.....I've sold up now, so have no books, notes etc, but I recall that a 37 tooth 3rd gear is also used elsewhere and is slightly different in circumference...hope that you have solved your problem without this 'help'!
WXboy64
by Leotech » Thu Jan 26, 2017 5:27 pm
Yes it was working before but in an engine I never really used.
Leotech
