engine and carb rebuild
Postby waynekemp » Sun Jan 22, 2017 4:56 pm
can anyone help i have had my li125 engine rebuilt and i have changed all gaskets etc on dellorto 18 carb when i come to kick over air/fuel mixture is coming out of air intake and not going to cylinder thank you
waynekemp
Re: engine and carb rebuild
Postby grandpa » Sun Jan 22, 2017 5:17 pm
Hi Wayne
Remove air bellows and place hand over carburettor you should feel suction when you kick engine over with throttle open Do you have good compression?
Could be ring stuck,head gasket leak,air leak piston in wrong way round inlet manifold leak
Good luck
Grandpa
grandpa
Postby waynekemp » Sun Jan 22, 2017 5:35 pm
hi i have removed bellows and air fuel mix is being blown out under pressure[ you say the piston could have been put in wrong way round ] is that possible wayne
waynekemp
Postby grandpa » Mon Jan 23, 2017 11:49 am
Hi Wayne.
Yes the piston can be put in back to front,the arrow or 'S' stamped on the piston always faces exhaust port.However ,I have no personal experience of whether that would cause air to blow out rather be sucked in.Perhaps an Adult may come along and comment.If you haven't got a manual you need to buy "the complete Spanner's manual Lambretta second edition by Martin "sticky" Round.
Certainly air needs to be sucked in,(Induction) for it to run.Its a pain, but if no-one comes along with a better idea you may have to remove head to check that the arrow is facing down towards the exhaust.No need to take engine out....Rear shocker off bump stop off cowl off then head off!
good luck
Grandpa
Come on chaps 108 views and no comments :(
grandpa
Postby holty » Mon Jan 23, 2017 3:48 pm
normally mixture being expelled out of the carb would be down to too much inlet duration, in other words the inlet being open for too long, there are 2 main causes, inlet port too big, or piston skirt shortened too much. you say the engines been rebuit, is it a new piston, did you compare to the old one, if shorter that could be your issue, or has the barrel been butchered by a diy tuner? the suggestion about piston wrong way round is worth a check but dont think it would cause it to blow out the way you suggest, who rebuilt the engine and what knowledge of the engine do you have ?
holty
holty
Postby waynekemp » Mon Jan 23, 2017 9:06 pm
thanks for info i have bit the bullet and ordered a new i50 cylinder and piston kit so i know all parts the same by the way the piston was in the right way thank for help
waynekemp
Postby hullygully » Tue Jan 24, 2017 6:42 pm
does it only happen when your fuel tap is turned on? 8-)
Postby byron » Wed Jan 25, 2017 12:34 pm
grandpa wrote:...Yes the piston can be put in back to front,the arrow or 'S' stamped on the piston always faces exhaust port.
... generally the rule, but I have known pistons to have the arrow stamped incorrectly... check the transfer cutouts line up, and the ring peg position is also a clue
byron
Users browsing this forum: Baidu [Spider] and 74 guests
