Reverse pull front brake.
Postby St George » Thu Jan 19, 2017 6:13 pm
I have fitted a brand new series 3 front disc ( standard Type ). I have been looking at converting to reverse pull set up.
I have looked at three kits as follows.
Rimini Lambretta £38.50
Ebay UK £25.00 free post
Cambridge Lamb' £7.94
They all look the same, am I missing something, big difference in prices. Thanks.
St George
Re: Reverse pull front brake.
Postby Storkfoot » Thu Jan 19, 2017 7:47 pm
Depends what parts you already have. Rimini part RLC005 £6.50 makes life a bit easier in that you don't have to tap and drill anything. Also, Scooter Restorations cable:
Front Disc Brake Cable (Grey) (14-71h)
I don't bother with those cable guides as, in my experience, they vibrate themselves to bits. Judiciously placed cable ties are better.
Lastly, you may wish to consider placing petrol pipe (8mm diameter) over the cable. This tends to keep the cable away from the tyre anyway.
Postby Fast n Furious » Fri Jan 20, 2017 12:59 am
Back in the 70's we used to use gold effect shower hosing to stiffen up and decorate the part of the cable you get to see. How tacky was that?
Postby CHRIS in MARGATE » Fri Jan 20, 2017 8:55 am
And then B & Q opened up and the range of colours was endless lol.
Postby St George » Fri Jan 20, 2017 4:18 pm
Hi Storkfoot. I have found the Rimini website, is there anywhere in the UK I can purchase that part RLC005.
Thanks for replies lads.
St George
Postby Warkton Tornado No.1 » Fri Jan 20, 2017 5:18 pm
You can use standard SIII components, either back brake or gear/clutch cable adjusters from memory.
Although any set-ups I've ever done will have a ferrule & lock nut fitted, I've always adjusted the cable via the lower nyloc nut as it's just so much easier.
I hope the image on this site helps:
http://www.racinglambrettas.com/yourscooters/dl125.htm
Postby St George » Fri Jan 20, 2017 6:09 pm
Many thanks for the image, similar to what I have seen before.
St George
Postby Storkfoot » Fri Jan 20, 2017 8:17 pm
St George wrote:Hi Storkfoot. I have found the Rimini website, is there anywhere in the UK I can purchase that part RLC005.
To my knowledge, no. I recently ordered one with a few other bits and bobs. Only light stuff so the postage was, from memory, 10 euros.
Postby CHRIS in MARGATE » Fri Jan 20, 2017 8:45 pm
I never bought any special parts to facilitate this modification.
Postby Rich Oswald » Fri Jan 20, 2017 11:14 pm
CHRIS in MARGATE wrote:I never bought any special parts to facilitate this modification.
Nor me.
Postby St George » Sat Jan 21, 2017 4:55 pm
Will have a look as soon as I can defrost my fingers. Many positive replies lads, thank-you.
St George
Postby Tractorman » Sat Jan 21, 2017 8:04 pm
All you will need is something to fit the outer cable to the ferrule. A cable adjuster for a carb will do nicely.
Postby Storkfoot » Sat Jan 21, 2017 10:36 pm
Postby St George » Sun Jan 22, 2017 4:52 pm
Thanks for all the input lads, I had a quick look in the garage this morning, I think I now have all the parts that I will need. Still too cold to sit on a garage floor. Should warm up next week. Regards :)
St George
Users browsing this forum: dave81 and 61 guests
