Starting point
Starting point
Postby Cellardyke » Fri Jan 20, 2017 7:33 am
Any advice in regards to jetting starting point for a PWK 28 on a standard 200cc engine ???
Cheers in advance.
Cellardyke
Re: Starting point
Postby CHRIS in MARGATE » Fri Jan 20, 2017 8:03 am
110 -115 -120 main
32 -36 - 38 pilot
May need a weaker needle JJK mid clip
Re: Starting point
Postby Cellardyke » Fri Jan 20, 2017 8:20 am
Cheers for that m8
Cellardyke
Re: Starting point
Postby drivera » Fri Jan 20, 2017 9:09 am
I would try bigger on the main jet 126 - 128 due to the ethanol sh*te in the fuel , pilot around 40 , if you need genuine spares splat shop in Chesterfield stock proper keihin bits
drivera
Re: Starting point
Postby CHRIS in MARGATE » Fri Jan 20, 2017 9:29 am
I run my 225 with expansion pipe on a Koso ( almost identical) open mouth on a 115 main and 34 pilot. 10,000 miles and it's on the rich side.
Re: Starting point
Postby Cellardyke » Fri Jan 20, 2017 10:58 am
Cheers Chris and Drivera.
Cellardyke
Return to Carburettors
Users browsing this forum: Google [Bot] and 25 guests
