Dial gauge and bracket source?
Postby AlG » Tue Jan 17, 2017 10:17 am
Any recommendations where to buy a dial gauge and bracket for setting TDC and measuring timing? I have seen the brackets online in SR and MB that attach across two head studs, but wondered if there were any other types and where to buy?
AlG
AlG
Re: Dial gauge and bracket source?
Postby foremanbob » Tue Jan 17, 2017 11:05 am
I used the SR bracket for my small block... but doh! then realised it doesnt fit large block... Use positive stop method now....
foremanbob
Postby Warkton Tornado No.1 » Tue Jan 17, 2017 12:09 pm
I must admit to have simply modified an old spark plug which has a concentric collar on top with a grub screw either through the spark plug hole (on central plug engines) or a piece of RSA (Rolled Steel Angle) to hold the DTI with the head off.
It never occurred to me to buy an appropriate tool or to consider the likely cost as....I own Lambrettas, which is cost enough :roll:
Likewise, my DTI’s came from Car Boot Sales or similar. The best DTI’s have a lug on the back to attach to a piece of RSA.
Postby Tractorman » Tue Jan 17, 2017 1:05 pm
Warkton Tornado No.1 wrote:I must admit to have simply modified an old spark plug which has a concentric collar on top with a grub screw either through the spark plug hole (on central plug engines) or a piece of RSA (Rolled Steel Angle) to hold the DTI with the head off.
I agree with your way, using I dial gauge you may need to allow for the dwell at TDC.
Postby corrado » Tue Jan 17, 2017 2:00 pm
MB out of stock but Brolam list them at £40 for the kit. Elongated holes so fits large and small blocks.
http://www.ebay.co.uk/itm/Lambretta-Ves ... Sw2xRYe7Gn
corrado
Postby AlG » Tue Jan 17, 2017 9:13 pm
Many thanks for the ideas and offers. I think I am going to have a go at making my own with an old imperial 0.0005" DTI I acquired and some odd bits of angle I have lying around. Shouldn't cost more that the market rate of £15, even if I damage a few drill bits and a hacksaw blade along the way.
AlG
AlG
Postby Donnie » Tue Jan 17, 2017 9:21 pm
I used one of these off ebay http://www.ebay.co.uk/itm/0-01mm-Clock- ... SwHjNV-kWI at less than 11 quid, plus a bit of metal bent to shape, drilled two holes, job done
Here it is on my bantam rebuild ImageUntitled by Donnie Canning, on Flickr
Donnie
