HxPaul wrote:Hi Phil, Lambrettas might be different but on A Vespa if you put the side stand on the left (the kerbside),the weight of the engine is all on the other side and the slightest touch will make the scooter fall over to the right side.
rossclark wrote:Seen some quite trick side stands that fit near the back of the chain case on chops and cutdowns
Scooterlam wrote:Mine on left.
Most important is to fit so if the spring fails it will trail rather than dig in.
Users browsing this forum: No registered users and 161 guests
