Can anyone tell me what the 2 oils seals are for as supplied with the Targaline gear change kit ?
ROClarke wrote:Morning all
bike grim wrote:Are they instead of a gasket under the swivel mount? I didn't use mine.
HxPaul wrote:I dont see any oil seals in that photo,I can see one o-ring that goes on top of the gear swivel.
gizmo wrote:ROClarke wrote:Morning all
Found this post while looking for an answer to the o ring issue. Did you remove the o rings from above and below the swivel. I can understand the keeping dirt out reason but the swivel is very stiff with them fitted
Users browsing this forum: B1gD0gu3, Google [Bot] and 146 guests
