The instruction booklet for my Series 2 says that the fork links should be greased every 2500 miles
Cheers!
507VBH wrote:Hi,
The instruction booklet for my Series 2 says that the fork links should be greased every 2500 milesAs it's been off the road for decades, I guess they may need some grease. However there is no grease nipple on the fork link pivot bolts. There is a grease nipple on the bottom of the links though. Is it possible to remove the fork link bolts and push some grease into the bush without the whole link + spring assembly falling apart?
Cheers!
