carbs
carbs
Postby RENNIE » Tue Jan 03, 2017 3:06 am
HI
Warm starting on standard machines these days with unleaded fuel ???? Anybody got any results?
Thanks Alan
RENNIE
Re: carbs
Postby Knowledge » Tue Jan 03, 2017 8:34 am
Alan,
i don't know what question you are asking.
Have you a problem with warm starting? Do you think that a combination of unleaded fuel and old carbs is the cause?
Martin
Re: carbs
Postby Meds » Tue Jan 03, 2017 11:03 am
viewtopic.php?f=10&t=4449
Have a look at this topic or do a Search on warm starting, it crops up regularly.
I had big warm starting issues because of spit back, just learned to cope with it by switching the fuel off and keeping the scoot running for a few mins before shutting it down. Starting it without fuel on and if that failed pulling the air hose off getting it running then putting it all back together.
I don't beleive mine was caused by any one issue, I think it was a combination of the carb/timing/piston-barrel-head wernt right. Yours may be different.
I only completly cured my problems by fitting a modern cylinder kit and a 30mm delly, starts first or second kick now.
Meds
Re: carbs
Postby CHRIS in MARGATE » Tue Jan 03, 2017 11:35 am
Never had a problem whether it's been stood for 5 mins or 5 hours.
Timing
Float
Worn Rings
Return to Carburettors
Users browsing this forum: No registered users and 8 guests
