Camb Lamb pepper pot hydraulic brakes
Postby Covboy » Mon Dec 26, 2016 5:45 pm
Hi
Is anybody using these ? would appreciate some reviews. RLC equivalent is £500 more...
http://www.lambretta.co.uk/shop/disc-br ... -3076.html
Re: Camb Lamb pepper pot hydraulic brakes
Postby Donnie » Tue Dec 27, 2016 12:25 am
Juuuuust to be clear.
They are for sale on Camlam, but not made by them etc, they are simply resold by them.
The pepper pot front discs at 250 ish are vietnamese. Im not really prepared to say more about them :-/
Donnie
Postby Covboy » Tue Dec 27, 2016 8:33 am
Thanks Donnie - that's enough for me ....
Postby Donnie » Tue Dec 27, 2016 10:38 am
Don't just judge on my experience, though it wasn't good and was a fairly early one where it wasn't possible to get tubeless rims on one?
Normal rims fitted it, tubeless didn't. Tried a normal drum front and both tubed and tubeless fitted, so basically the radius on the pepper pot needed reducing slightly :-(
Others' may have had better experience or the same. Personally I have one of these, in fact ive had a couple on differennt scooters with no issues. http://www.lambretta.co.uk/shop/disc-br ... -3302.html
on saying that the rubber hose is crap so you'll need to get or make up a bespoke one to get best benefit.
Donnie
Postby Covboy » Tue Dec 27, 2016 1:36 pm
Thanks - I'll look into those
Postby bike grim » Tue Dec 27, 2016 2:39 pm
Donnie on that particular brake setup, is your wheel absolutely central in the fork. Same gap on each side etc?
Postby Donnie » Tue Dec 27, 2016 3:57 pm
probably an offset of between 3 to 5mm if that, not been a problem for the last 10 or so years it's been on there though.
Seems a common theme with outboard discs though, think some use washers to space things but I didnt bother as it was close enough that its barely noticable unless you look real close and, as I say, in practice it makes no difference to the handling.
Donnie
Postby bike grim » Tue Dec 27, 2016 4:33 pm
Ok cheers
Postby corrado » Mon Jan 02, 2017 1:35 am
I've got a Saigon SC "pepper-pot" style one that won't fit on my Sip rim [as per Donnie} but I've got a Spaq one that fits fine.
corrado
Postby Rich Oswald » Mon Jan 02, 2017 12:31 pm
corrado wrote:I've got a Saigon SC "pepper-pot" style one that won't fit on my Sip rim [as per Donnie} but I've got a Spaq one that fits fine.
Phew, i'm really glad you have just said that Martin as I was panicking over the Spaq one you sold me.
