Ancilotti exhaust problem
Postby Revvers » Thu Jul 24, 2014 6:02 pm
Hello all. I have fitted an Ancilotti clubman style exhaust to my series 3. It appears to catch both the side stand and kick start lever. I have made sure that the correct down pipes are fitted and the exhaust runs well. It looks like I need to file down the outer rim of the exhaust box to clear both the stand and the kick start. Is this right?? Thanks
Revvers
Re: Ancilotti exhaust problem
Postby Fireman Ash » Thu Jul 24, 2014 8:44 pm
I managed to not have to damage my new laqured exhaust ancilotti and took the stand off and using a small piece of scaffold and with the stand securely protected in a vice went about slowly dry bending it outwards until it cleared the exhaust. only about 5-10mm. Not noticable once fitted again ;) good luck bro
Fireman Ash
Postby Revvers » Thu Jul 24, 2014 9:39 pm
Cheers mate. Did you have a problem with your kickstart too?
Revvers
Postby MK Monty » Fri Jul 25, 2014 8:33 am
Yes to both faults. File and a hammer. Thats Lambrettas for you or should I say the quality of parts sold today.
Ps buy decent tools you will need them.
MK Monty
Postby Fireman Ash » Sat Jul 26, 2014 11:59 pm
Yes I did so filed that so as to clear the pipe without damaging the nice new exhaust
Fireman Ash
Postby peejay » Sun Jul 27, 2014 9:54 am
depending on how much of an issue this is it may be possible to elongate the hole in the stand "hook" bracket and force the stand one way or the other but this will only gain you a couple of mm.
it is common to have to cut a small part of the pedal stop plate off of some pedals but not all
Postby Rich Oswald » Wed Jul 30, 2014 11:15 pm
Fireman Ash wrote:I managed to not have to damage my new laqured exhaust ancilotti and took the stand off and using a small piece of scaffold and with the stand securely protected in a vice went about slowly dry bending it outwards until it cleared the exhaust. only about 5-10mm. Not noticable once fitted again ;) good luck bro
Just bent my stand out a bit also with a scaffold pole but just took the scooter off the stand and leaned it against a wall to do it. Didn't need to remove the stand.
Postby bigbthesoulman » Wed Aug 06, 2014 9:40 am
Bought same exhaust once,same issues,couldn't get oil level plug out either,cut my loses sold it after 100 mile and bought AF clubman happy since
bigbthesoulman
Postby Revvers » Thu Aug 07, 2014 12:54 pm
I must admit, I bought it for a bit more oomph and to run a bit quieter than my standard clubman (+ Mugello 185 kit) and it does neither. Wouldn't have bothered if I'd known then.. Etc. v disappointed
Revvers
Postby bigbthesoulman » Mon Aug 11, 2014 10:23 am
yes i was as well, :(
bigbthesoulman
Postby Scooter Paul » Mon Aug 11, 2014 12:33 pm
I believe later ones were improved especially as regards the oil level plug being accessible. I'd like to know if this is the case as I need another clubman. Are they now a three piece design?
Paul
Scooter Paul
Postby Revvers » Tue Aug 12, 2014 12:28 pm
I bought mine in March-ish of this year from Cam Lam. The oil drain plug is accessible and my only issues are with the kickstart lever (now sorted) and stand not coming right up, although the stand is new and my old one was ok! It came as a 2 part kit
Revvers
Users browsing this forum: No registered users and 38 guests
