Adam_Winstone wrote:I'm trying to get my head around what marks we've got where so forgive me if I'm a little confused about what we do or don't have.
What I can say is that you can apply the reverse method to keep a single mark on mag housing and put the range on the flywheel edge, should you chose to, which is what Scooter Center have done with their BGM flywheels.
So have you got a single mark on the mag lip and one arrow mark on the flywheel edge OR do you have one TDC mark on the mag lip and 2 rotational marks on the flywheel?
johnnyXS wrote:I have never used the positive stop method myself as I always use a pencil or screwdriver in the spark plug hole and rotate anti clockwise until the piston hits the highest point . (I'm lazy) then I always use a degree wheel to mark and set advance
I'd be interested to know how much differnce in accuracy between the two methods .
I suspect the greatest potential improvement in timing and performance is likely to be in the final choice of advance setting.
a-teamlambretta wrote:you are using the positive stop method , im on a smashed out spark plug with a bolt through the middle , then screwed into plug hole to stop the piston going all the way to tdc.
LateAgain wrote:a-teamlambretta wrote:you are using the positive stop method , im on a smashed out spark plug with a bolt through the middle , then screwed into plug hole to stop the piston going all the way to tdc.
Out of interest what did you use to smash the plug internals out? I started to make a +ve stop a few years ago, but gave up when I couldn't get the plug hollow. Been meaning to revisit it every time I see it sitting on the shelf !!!
Users browsing this forum: No registered users and 136 guests
