Mel K wrote:Or whether to have a hidden master cylinder or not ?
CHRIS in MARGATE wrote:It's the cutting /drilling through that rare headset that makes you think. I went through the bottom but you do have to cut a deeper slot than you first plan for because the headset top overlaps. Total time was about 75 mins. Worth it.
HxPaul wrote:If you dont want to drill your headset rout the hose this way.http://scootrs.com/images/restoration/b ... dset_2.jpg
gaz_powell wrote:Life is easier with a goodridge or venhill braded hose instead of the thick rubber ones often supplied.
Donnie wrote:Mel K wrote:Or whether to have a hidden master cylinder or not ?
NOT, they are generally (note i said generally) crap
