CHRIS in MARGATE wrote:I believe you good go to 17 tooth front sprocket and get good results with a final gearing of 5.01:1 that will give you 61mph @ 6000rpm as opposed to 45mph @6000rpm. You will need a longer chain.
skip123 wrote:Johnny,
your links were helpful thank you, and yes I did use them and read the information they provide. However, from what I have read, previously and on the websites you suggested, it seems to me there is more to optimising gearing than numbers of teeth on cogs and sprockets. There's no right and wrong answer and I'm not expecting anything "on a plate", it's my decision to make after all. There is however a wealth of experience in the Lambretta community and numerous people willing to share their experience. If you're not one of those, so be it.
Do you seriously think that any LCGB members are going to know better than MB ?
johnnyXS wrote:I think that a vital piece of information in Skips initial post is being completely overlooked.![]()
Skip has stated that he intends to keep the existing gearbox which is an early series 3 Li125 gear set
This gearbox has a very high first gear ratio which means that it will rev high very quickly requiring a quick gearchange up to second gear.
The other problem with this particular gearbox is there is a huge gap between first and second gear and again between second and third gear .This will result in the engine falling flat on its face with the first two gear changes . This power drop will be made a lot more pronounced with a bigger capacity engine like a 198cc.
Although a chaange to a 16T drive sprocket will improve the overall final drive ratio to 5.30 the big gaps betwween gears will be more noticable.
If you are looking for a sensible spread of gears that have the strength to take the exta power and give you a respectable final drive ratio of 5.22 (same as LiS150 series 3 special ) and good low down grunt then the only sensible option is to fit a Li150 gearbox and possibly add a 16T sprocket for an improved 4.9 final drive ratio and higher top speed.
Basically that is what Mark Broadhurst is saying in the first link I provided.
If anyone has a better option than that i'd be interested to hear it
Users browsing this forum: Baidu [Spider] and 134 guests
