image hosting site over 5mbThe ability to post messages is restricted to LCGB members. Any questions contact us at lcgbadmin@googlemail.com
Adam_Winstone wrote:What kit is this from?
images upload
free photo upload
image post
Adam_Winstone wrote:From the photos, if bore is still in reasonable shape then run it on the top ring only and look into other piston options. NB: Single ring kits are very common but ring replacement tends to be needed at shorter intervals than 2 ring pistons.
A pal of mine was having issues with his kit breaking rings and when he nipped up and did in another ring/piston on the way to IOM, we had to decide whether we would fit his new piston (carry a spare) with 2 rings or fit it with just one, which would leave us a 'get out of jail' option if he somehow did another one on our trip (we were only about 30 miles out of Oxford at the time!). We opted to fit the top ring only and the bike ran without issue for the rest of the trip (choke on!) and then ran perfectly well on this top ring only for plenty of miles afterwards.
I'd figured out what the top end was after your previous photos
What is your bore and compression height of your piston? I ask as you may have other options.
