front wheel removal
front wheel removal
Postby ROClarke » Tue Dec 27, 2016 8:35 pm
If the rear wheel is still in place presumably you lift the front bars and the wheel drops out ?
obvouisly after removing 19 mm nuts and shocks.
ROClarke
Re: front wheel removal
Postby ToBoldlyGo » Tue Dec 27, 2016 8:40 pm
I prefer to put a block of wood under the stand legs and raise it off the ground so that the wheel can drop out cleanly and with both hands on it.
ToBoldlyGo
Postby HxPaul » Tue Dec 27, 2016 9:26 pm
+1
Postby ROClarke » Wed Dec 28, 2016 11:23 am
ToBoldlyGo wrote:I prefer to put a block of wood under the stand legs and raise it off the ground so that the wheel can drop out cleanly and with both hands on it.
Nice one,cheers
ROClarke
Postby Knowledge » Wed Dec 28, 2016 12:50 pm
ROClarke wrote:.....obviously after removing 19 mm nuts and shocks.
You won't need to remove the shocks, but you will find that the wheel stays in place until the washers behind the 21mm nuts are removed. Once the washers are displaced, things tend to happen quite quickly.
BTW, the nut is 21mm so you can remove it with a spark plug spanner.
Users browsing this forum: Baidu [Spider] and 68 guests
