Gearbox question
Gearbox question
Postby Toddy » Sat Dec 24, 2016 1:05 pm
A mate bought an LI150 gearbox off FB can anyone recognise or advise on the markings on the first gear cog ?
Re: Gearbox question
Postby ToBoldlyGo » Sat Dec 24, 2016 1:29 pm
Indian, or possibly remade. Although, I have had an Indian LI gearbox and don't remember markings like that.
ToBoldlyGo
Postby a-teamlambretta » Sat Dec 24, 2016 1:31 pm
indian ?
a-teamlambretta
Postby a-teamlambretta » Sat Dec 24, 2016 1:32 pm
whats on the rest ?, could be just a replacement first gear??
a-teamlambretta
Postby Toddy » Sat Dec 24, 2016 1:56 pm
a-teamlambretta wrote:whats on the rest ?, could be just a replacement first gear??
Nothing mate no stamping or anything
Postby HxPaul » Sat Dec 24, 2016 2:15 pm
I have a series 2 Li 125 gearbox from 1960 and the edge of the teeth are no-where near as worn as that.It looks like they haven't been hardened properly.Is it a cheap unbranded Indian gearbox.
Postby Toddy » Sat Dec 24, 2016 2:21 pm
HxPaul wrote:I have a series 2 Li 125 gearbox from 1960 and the edge of the teeth are no-where near as worn as that.It looks like they haven't been hardened properly.Is it a cheap unbranded Indian gearbox.
That's what I'm trying to find out buddy the lad bought it in good faith dropped it at mine and when I checked it I suspected it wasn't Italian :(
Postby Steve J » Sat Dec 24, 2016 2:58 pm
I don't think it's wear on the side of the teeth - it looks as if a chamfer has been machined on the side of the teeth for some strange reason - maybe to clean up some rough edges? I seem to remember that Italian cogs don't have such a large chamfer on the sides of the teeth, and there's nothing in the gearbox which would cause the teeth to wear in that way.
Steve J
Postby Adam_Winstone » Sat Dec 24, 2016 4:24 pm
Postby Toddy » Sat Dec 24, 2016 6:51 pm
Adam_Winstone wrote:Kelvinator parts?
http://www.scooterrestorations.com/lamb ... lower-koi/
Gearbox Adam ?
Postby piskie » Sat Dec 24, 2016 6:58 pm
I am of the same opion as adam winston x
piskie
Postby Adam_Winstone » Sat Dec 24, 2016 10:30 pm
KOI marked on gear in photo... it's the only time I've seen KOI on anything, as per the link I posted.
Postby Toddy » Sat Dec 24, 2016 10:37 pm
Adam_Winstone wrote:KOI marked on gear in photo... it's the only time I've seen KOI on anything, as per the link I posted.
Cheers Adam are they any good ? And merry Xmas mate
Postby Adam_Winstone » Sun Dec 25, 2016 1:21 pm
Hi Toddy,
Can't give any first hand experience of the gear quality but most of the genuine Indian stuff, from various factories, is very good. It is only when you start dealing with the aftermarket stuff, from anywhere, that the standards frequently slip.
You too. Merry Christmas and I look forward to seeing you in 2017.
Adam
Postby holty » Sun Dec 25, 2016 1:23 pm
as with anything indian i would check carefully, make sure no chips on teeth or wear, check the hole in the centre is not too large, i put them on an old layshaft and make sure they are a reasonable fit, i threw a couple of gears away the other week they were way too slack on the layshaft, also fit the full stack on the layshaft and make sure they are higher than the end of the layshaft, i think you will already know this, af close ratio boxes use indian parts, ive got one in my rb and they will take some abuse so i would use, they just dont look very nice compared to italian gears or spanish.
holty
holty
Postby Toddy » Sun Dec 25, 2016 10:16 pm
Thanks all
Users browsing this forum: L111amo and 67 guests
