Vapor speedo
Vapor speedo
Postby gizmo » Sat Dec 17, 2016 3:56 pm
Bit of advice, not sure wether to fit a sip or vapor speedo, does the vapor need a battery? And any pro's or con's for one against the other.
gizmo
Re: Vapor speedo
Postby jonashford » Sun Dec 18, 2016 12:41 am
fit a gamma, vapor better than sip, but if u want to go faster fit the sip lol
jonashford
Re: Vapor speedo
Postby Fast n Furious » Sun Dec 18, 2016 4:07 pm
Gizmo....How's your eyesight?
If its as aged and long sighted as mine then all you will see with a SIP is the digital speed readout and possibly the analogue revcounter (These can be inversed on the later models)
I have one, and although it works very well I can't see the temperature or odometer displays without my glasses and if I wear my glasses I can't see the road properly. So, glasses under a fullface helmet get the boot. I can see the speed display and that fulfils any legal obligation.
I have no experience with other brands but if you are of a certain age then Size matters. This may well have an important influence on your decision.
Re: Vapor speedo
Postby ToBoldlyGo » Sun Dec 18, 2016 4:44 pm
What we really need is a heads up display built into the helmet. 8-)
ToBoldlyGo
Re: Vapor speedo
Postby gizmo » Sun Dec 18, 2016 5:07 pm
Fast n Furious wrote:Gizmo....How's your eyesight?
Jeeps, sounds like me. Might be just as well sticking to a shaky needle.
gizmo
Re: Vapor speedo
Postby Toddy » Sun Dec 18, 2016 10:49 pm
jonashford wrote:fit a gamma, vapor better than sip, but if u want to go faster fit the sip lol
+1 for the gamma great unit and big enough display to see as well
Re: Vapor speedo
Postby Bilko » Sun Dec 18, 2016 11:53 pm
I've had the Vapor in the past which was good, but I'm currently using a GammaTech and it's superb. Really easy to set up and use. I'd definately recommend it.
Bilko
Re: Vapor speedo
Postby Fast n Furious » Mon Dec 19, 2016 2:32 am
I'd like to see a proper made one for the series 3 headset with large digits showing MPH,CH temp and EGT. I could live with RPM on an arc bargraph. Odometer could be small or on a next page.
Re: Vapor speedo
Postby Knowledge » Mon Dec 19, 2016 8:00 am
Gizmo,
The answer to your problem might be vari-focal glasses. It did it for me.
Just bring another option to the table, there are a range of products from Acewell. Big digital read-out, plus temp gauges and idiot lights. I like mine.
Re: Vapor speedo
Postby gizmo » Mon Dec 19, 2016 10:12 am
Do all these just require a live feed in headset without using an independent battery? I have never bothered previously but in process of building a RB 25 and would like to be able to keep an eye on temperature readings
gizmo
Users browsing this forum: B1gD0gu3 and 80 guests
