Fuel cap.
Fuel cap.
Postby Jimmyjames » Wed Dec 07, 2016 1:22 pm
Hi all has anyone found a better fuel cap then the standard one?
Would love to stop the fuel leaking from the cap .
Cheers . :oops:
Jimmyjames
Re: Fuel cap.
Postby ToBoldlyGo » Wed Dec 07, 2016 1:24 pm
You could firstly replace the seal and then you could press down on the tangs to make the cap tighter. I don't think there is an alternative, short of getting a new one.
ToBoldlyGo
Re: Fuel cap.
Postby Jimmyjames » Wed Dec 07, 2016 1:27 pm
Done that mate :D no improvement.
Jimmyjames
Re: Fuel cap.
Postby ToBoldlyGo » Wed Dec 07, 2016 1:33 pm
I think the scientific term for that is knackered. I don't know. You can only try another cap.
ToBoldlyGo
Re: Fuel cap.
Postby missing lynx » Wed Dec 07, 2016 1:58 pm
is it a std tank?
Re: Fuel cap.
Postby Jimmyjames » Wed Dec 07, 2016 4:52 pm
No sigon stainless. 8-) .
Jimmyjames
Re: Fuel cap.
Postby ToBoldlyGo » Wed Dec 07, 2016 7:13 pm
Just check the actual neck of the tank. I had a remade tank and could I stop the cap leaking? It wasn't the cap as it turned out. The actual neck had come loose and would move up and down with pressure.
ToBoldlyGo
Re: Fuel cap.
Postby missing lynx » Wed Dec 07, 2016 11:58 pm
I had the same couldn't fill it right up a no matter what I tried it wouldn't stop leaking
Re: Fuel cap.
Postby coaster » Thu Dec 08, 2016 7:17 pm
I'm having similar problems with a Diablo tank and a Camlam one. The caps (I've tried a few) need the tabs fettling just to allow the thing to turn an lock and then leak when full. I wish I'd tried the caps before fitting the tanks as it is the angle (or lack of) of the ramps in the neck that are the issue.
Re: Fuel cap.
Postby Jimmyjames » Thu Dec 08, 2016 10:54 pm
Looks like a losing battle. :)
Jimmyjames
Re: Fuel cap.
Postby Warkton Tornado No.1 » Fri Dec 09, 2016 12:09 am
Everything said so far is unfortunately only to be expected. Age &/or quality take their toll. :(
I suppose you've tried a trick that I had work for me?
Fit two of the rubber cap seals or make a bespoke, thicker one?
Re: Fuel cap.
Postby burnside » Fri Dec 09, 2016 12:41 am
I've got 2 standard tanks and 1 Oiltek, all with standard fuel caps and never had an issue with any of them, even when filled right to the brim
burnside
Re: Fuel cap.
Postby Warkton Tornado No.1 » Fri Dec 09, 2016 1:45 am
Post by burnside » Fri Dec 09, 2016 12:41 am
For sure, not everybody does have problems with tank caps. My own have been few, thankfully.
However, wherever the problem arises, those of us that have been less fortunate can only try & pitch in with suggestions that we hope will help. ;)
Re: Fuel cap.
Postby EddieStone » Fri Dec 09, 2016 9:28 am
Is it definitely leaking out the cap? It's not leaking out of a join between the tank and the filler neck is it?
EddieStone
Re: Fuel cap.
Postby ToBoldlyGo » Fri Dec 09, 2016 1:06 pm
That's what happened to mine on a remade standard tank.
ToBoldlyGo
Re: Fuel cap.
Postby burnside » Fri Dec 09, 2016 2:10 pm
I guess what I was alluding to was that the fault is more likely to be the after market tank as opposed to the standard Lambretta fuel caps which the OP was suggesting was the problem, as I haven't had any issues with standard caps
burnside
Re: Fuel cap.
Postby Warkton Tornado No.1 » Fri Dec 09, 2016 3:13 pm
Post by burnside » Fri Dec 09, 2016 2:10 pm
Ha! Yes, of course.
If any of us have bought stuff recently that has all been spot-on, they should be doing the Lottery! ;)
Re: Fuel cap.
Postby EddieStone » Fri Dec 09, 2016 4:09 pm
I bought some fuel - that fitted inside the tank absolutely perfectly.
EddieStone
Re: Fuel cap.
Postby burnside » Fri Dec 09, 2016 6:02 pm
Ha! Yes, of course.
I've bought plenty of stuff that has been spot on, like my Oiltek tank, but also plenty of stuff that hasn't!
burnside
Re: Fuel cap.
Postby missing lynx » Fri Dec 09, 2016 9:45 pm
surly if we all sent or took bits back that didn't fit or work as they should the suppliers would start supplying bits that were fit for purpose. But as we all seem to do ( I'm guilty of this) take bits and fettle them and accept this is how it is the poor quality will continue even from so called quality suppiers
