squish
squish
Postby a-teamlambretta » Sat Mar 28, 2015 3:47 pm
Just changed head on an imola top end, squish is coming out at 0.80. Is this too close?. I am using packers top and bottom and don't want to add a gasket at the top, was hoping to get away without buying another packer. Cheers Simon
a-teamlambretta
Re: squish
Postby mickyb » Sat Mar 28, 2015 5:23 pm
wouldn't go below 1 mm, pref 1.2mm
mickyb
Re: squish
Postby Donnie » Sat Mar 28, 2015 8:36 pm
yep, 1.2 to 1.5
Donnie
Re: squish
Postby Wack » Sat Mar 28, 2015 11:22 pm
Fit a .5 base gasket= 1.3 mm
Re: squish
Postby rossclark » Sun Mar 29, 2015 2:18 am
Or a similar thickness head gasket, won't affect your port timings.
Re: squish
Postby hullygully » Tue Mar 31, 2015 11:06 pm
use 2 head gaskets you gready twat :?
Re: squish
Postby a-teamlambretta » Wed Apr 01, 2015 12:37 pm
dont want to use 2 gaskets as this may increase chances of leakage. will skim a bit off me head . but just incase mickey can you cut me some out of your cornflake packets , dont wnt to waist my own :lol:
a-teamlambretta
Re: squish
Postby Jeff t » Sun Dec 04, 2016 8:57 pm
Just rebuilding mine coming out at 1.1 I've a 0.3 head gasket, would you leave at 1.1 or fit the gasket
Jeff t
Re: squish
Postby dscscotty » Sun Dec 04, 2016 9:54 pm
1.1 is fine, as long as head/piston have good profile?
Re: squish
Postby johnnyXS » Sun Dec 04, 2016 11:34 pm
I think I've read of 0.8mm squish being used somewhere or other but as others say its bloomin tight with little margin for error.
It might be worth reading the 'Bang for Bucks' series of articles in Scootering mag as one of the early articles mentioned that a huge increase in power was found simply by reducing squish ;)
johnnyXS
Re: squish
Postby dscscotty » Sun Dec 04, 2016 11:45 pm
0.8- is ok on race spec motors, we run 0.8 on production class with av gas controlled fuel etc, road motors a side of caution is advisable, some people read to much!
Re: squish
Postby johnnyXS » Mon Dec 05, 2016 1:07 am
dscscotty wrote:0.8- is ok on race spec motors, we run 0.8 on production class with av gas controlled fuel etc, road motors a side of caution is advisable, some people read to much!
its a curse :lol:
johnnyXS
Re: squish
Postby HxPaul » Mon Dec 05, 2016 9:35 am
The problem with road going scooters is,there not rebuilt on a regular basis and a build up of carbon in the combustion chamber of the head and the top of the piston can bring them very close together,that and the close squish of less than 1.00mm and they could be touching.
Re: squish
Postby Fast n Furious » Thu Dec 08, 2016 1:56 am
Generally speaking , it is safe and wise to limit the quish to 1.0% of the conrod length for sub 10,000rpm engines
Re: squish
Postby johnnyXS » Thu Dec 08, 2016 9:17 am
HxPaul wrote:The problem with road going scooters is,there not rebuilt on a regular basis and a build up of carbon in the combustion chamber of the head and the top of the piston can bring them very close together,that and the close squish of less than 1.00mm and they could be touching.
I've been thinking about this and in my experience engines are to a large extent self cleaning .
Yes carbon can build up on the piston crown but it can only build up in the space that we give it. Using an engine through its full range and getting it thoroughly warm will prevent carbon build up to a large extent. Its the slow running pottering around Town commute milage that is so detrimental to engines
Once the squish area is filled with carbon on top of the piston it cannot build any further due to the constant detonation and squishing . The more squish depth we allow betweeen the piston crown and the head ....the more room we allow for carbon to build up. Once there is any appreciable carbon build up I would imagine it would have the effect of increasing the compression ratio ...giving potentially more power ...on the other hand the rough surface on top of the piston will slow down the flame travel under detonation which will have a slightly negative effect on power.
Come this August I will have been wrenching on Scooter, motorcycle and car engines for exactly 50 years and in all that time I have never read or heard of a single instance where carbon build up has been the direct cause of engine failure. ;)
I'd be interested in others experience on this though
johnnyXS
Re: squish
Postby Jeff t » Thu Dec 08, 2016 8:47 pm
Well started some good debate, I'll be going with the 1.1 when I stripped it down the carbon was fairly minimal mainly around the crown of the piston but nothing excessive.
Jeff t
Re: squish
Postby johnnyXS » Thu Dec 08, 2016 9:09 pm
I'll probably be going with around 1.0mm myself Jeff , after reading the power gained in Daryls recent Bang for Buck article . That was an astonishing increase. :o
johnnyXS
Re: squish
Postby Fast n Furious » Mon Feb 13, 2017 2:41 am
Once the squish area is filled with carbon on top of the piston it cannot build any further due to the constant detonation and squishing . The more squish depth we allow between the piston crown and the head ....the more room we allow for carbon to build up. Once there is any appreciable carbon build up I would imagine it would have the effect of increasing the compression ratio ...giving potentially more power ...on the other hand the rough surface on top of the piston will slow down the flame travel under detonation which will have a slightly negative effect on power.
I can provide some testimony here Jonny.
It was back in 78/79.... A mate of mine, a couple of lockups down, serviced lammy's on occasion.
The rider (a really old bloke, who was probably actually younger than most of us now. LoL) said the scoot had no power.
When the exhaust was removed, it crashed to the floor.......... It weighed a ton. It was completely blocked up with carbon. The exhaust port was the size of a pea and the piston wasn't much better.
It was common practice in the days before 2 stroke oil when you had to use 20/50w or similar to do the job, leading to exhausts, pistons and exhaust ports to block up this way.
I can remember as a youngun having to decoke 2 stroke exhausts with a propane gas torch. Man did they stink. The neighbours loved me! :roll:
How times have changed.
Re: squish
Postby Warkton Tornado No.1 » Mon Feb 13, 2017 6:22 pm
a-teamlambretta wrote:Just changed head on an imola top end, squish is coming out at 0.80. Is this too close?. I am using packers top and bottom and don't want to add a gasket at the top, was hoping to get away without buying another packer. Cheers Simon
As somebody that has fallen foul of too small a squish & other head sealing problems, the rules that I apply for first class components are:
Road: Minimum squish 1 mm
Race (no piston bushes): Minimum squish 0.7 mm
Race (piston bushes): Minimum squish 0.85 mm
Road & Race: No cylinder head gaskets without exception
BTW. IMHO the object of aiming for the optimum, minimum, squish is to transfer heat from the piston crown to the cylinder head as well as optimizing the burn of the cylinder contents. It does have an effect on the compression ratio, but that is best controlled by other means, not by juggling with the finite squish figure ;) .
Users browsing this forum: No registered users and 49 guests
