The Ginger Stepchild....
Re: The Ginger Stepchild....
Postby LateAgain » Sat Mar 05, 2016 1:45 pm
Wi two kids under 5 I only get an hour at a time Duncan! Place looks like a bomb site generally cos of it. Should really get a fire extinguisher in there for that reason.
LateAgain
Postby duncan1958 » Sat Mar 05, 2016 7:37 pm
LateAgain wrote:Wi two kids under 5 I only get an hour at a time Duncan! Place looks like a bomb site generally cos of it. Should really get a fire extinguisher in there for that reason.
A good fire extinguisher for non electrical fires is a good old squeezy bottle ( a la Blue Peter ) with water in it ,had one to hand when welding up old rusty cars years ago and setting light to sound deadning material was power for the course.
I assume you mention a fire extinguisher for any possible, fires not your youngsters :o
Although the squeezy bottle works just fine on youngsters on the one hot day of the year ;)
duncan1958
Postby LateAgain » Sun Apr 24, 2016 8:29 am
Bit of GSC progress, bodywork prep mainly.
The old sign writing had to eventually go
Mammoth filling session starts to tidy toolbox door area and top of loop
30+ hrs later filling and sanding
Plenty more prep work to go. Doing a couple of crash hats too.
My 1st lid... TMX2000!!!!
... and a piss pot. Probably only for leaning the bike on!
Leggies nearly finished, final coats of spray putty, nearly ready for final floor runner drilling. Leggies have been a bit of a nightmare to get straight. Should probably have used some new ones to save the endless filling and shaping.
GSC TBC...
LateAgain
Postby LateAgain » Sat May 21, 2016 9:37 am
More dry building, August Bank Hols deadline fast approaching for road trip with Brazillian LA.
Headset build up.
Knackered bar end
Went posh with MB brass bits for gearchange side
Stripped QA and noticed master cylinder mirror housing directly in cable route
Dremel out. Sorted.
Back to gearchange side for Yam clutch lever fitting to match brake
Fitted MB stainless rod and QA gear wheel, don't know how effective it will be mind. Had to Dremel bout 20mm out of gear housing slot to get brass bush to sit in correct position to allow gear wheel to line up with cable slots. See above.
Headset top rim threads were knacked so got a blob of ally done and retapped.
It's an early Indian headset so still Italian styled. Bought a new Scootopia GP headlight unit from Corrado but the rim was a mile out, headset fault, not rim. Files out for more fettling.
Bingo. Bit more tweaking req'd, not perfect on the bottom edge but getting there
LateAgain
Postby Adam_Winstone » Fri Jun 03, 2016 7:13 pm
Coming on nicely :)
Postby peter357bikes » Wed Jun 08, 2016 7:21 pm
very enjoyable so far.
peter357bikes
Postby LateAgain » Fri Jul 01, 2016 4:21 pm
More dry building....
Horncase mounting as top lugs been cut off for shortened steering column. Welds to tidy.
Floor runner Mock ups and drilling using Vep runners, not an exact fit on the leggy curves.
Rear brake pin had previously been removed for racer styling, got given one off a mate but was a bit mullered
Needed some dimensions, which I got off BLA Nobbly
Brake pedal mounted
Rear brake cable support bracket
Prepping continues ...
Some 80s-Tastic add-ons. Kwaka dampers rubbed down and an 80s headlight grille.
GSC TBC...
LateAgain
Postby Vmakgp » Fri Jul 01, 2016 9:30 pm
LateAgain wrote:Cheers Russ... where to find a block of copper?
If you cannot get copper fella alloy will do
Vmakgp
Postby gaz_powell » Sat Jul 02, 2016 10:00 pm
Coming on well Paul, hope we get to see it with BLA in IOW.
What yamaha is the clutch from?
Postby LateAgain » Sun Jul 03, 2016 10:07 am
gaz_powell wrote:What yamaha is the clutch from?
No idea Gaz, it's an MB jobby, but they've since changed suppliers and don't come with the 'knuckles' anymore.
eBay but big postage.
401091537141
LateAgain
Postby LateAgain » Mon Jul 18, 2016 3:30 pm
Bit more dry building... all welds to be tidied later!!!
Hydraulic hose guides
QA throttle cable
Sorting out the loom
When I offered up the outer cables to check for routings, I wasn't happy with the way they entered and exited the frame,
the angles were too tight on the slots I had created. Out with a torch and some round bar...
Bingo.
GSC TBC...
LateAgain
Postby LateAgain » Sat Oct 01, 2016 2:02 pm
Not a lot to report lately.
Wiring all in place but not sleeved yet to make a loom. Not quite sure how to go about that yet.
Rigged up front hydraulic
Old skool
Bump stop sorted for 400/10
Getting ready for paint
LateAgain
Postby gaz_powell » Sat Oct 01, 2016 7:11 pm
Keep it coming!!!! I'm liking the paint idea!!!.
Some lovely little subtle touches.
Gaz
Postby LateAgain » Thu Dec 01, 2016 7:30 pm
Seem to have lost a load of Photobucket pics, so some build stages gone missing. Doh.
Anyway progress...
Had a stand made to aid spraying, no contact points on frame
Wiring loom made
Frame tube stripped
Sussing out and mixing 4 base candy colours
Trimming cowlings for (the b*stard) exhaust nut and Reed valve
Stuff ready for chroming
Building a spray booth in the garage
Getting ready for spraying and it's -4'C outside.
GSC TBC...
LateAgain
Postby Knowledge » Thu Dec 01, 2016 11:15 pm
Nice picture story. Keep it coming - it won't be -4degrees every night!
Postby Toddy » Thu Dec 01, 2016 11:54 pm
Great work mate , loving the story and spray booth :D
Postby gaz_powell » Fri Dec 02, 2016 8:20 pm
Come on Paul.......suspense is killing me!!!!
Postby bike grim » Thu Dec 08, 2016 8:55 am
Really impressed, keep it coming.
Postby Adam_Winstone » Mon Dec 12, 2016 9:57 pm
No wonder I've not seen you for a while... you've been busy!
Postby P D: SC Chester » Mon Dec 12, 2016 10:50 pm
This is better than sex. Mind you, if you could see my Mrs lying next to me, you would probably think a plastic rev n go was better.
Top work
P D: SC Chester
Users browsing this forum: No registered users and 52 guests
