RAL Codes
RAL Codes
Postby Toddy » Tue Dec 06, 2016 10:59 am
Anyone know if or Where i can get RAL paint codes for the two lambretta Paints below for a friend please
8019
8040
Cheers Toddy
Re: RAL Codes
Postby landybretta » Tue Dec 06, 2016 12:26 pm
From my experience a definitive conversion chart from Lechler to Ral codes does not exist.
If you do find a RAL code it may not be an exact match.
It would be better to use a supplier who can supply the paint using the Lechler code or can produce an exact match using a piece of the scooter.
If you want the code for powder coating I searched the internet for hours and was unable to find a match for the code I was looking for.
Good luck with your search.
landybretta
Re: RAL Codes
Postby waddo » Tue Dec 06, 2016 6:44 pm
Toddy wrote:Anyone know if or Where i can get RAL paint codes for the two lambretta Paints below for a friend please
8019
8040
Cheers Toddy
Hi Toddy.
I've got the full Ral colour code paint chips you can borrow if it helps mate. Like Landybretta says, there is no bang on match for original Lechler paint. But there are a few that are very very close. We tend to use them on customers scooters, when they want a cheaper restoration/rebuild carrying out, and want the forks, hubs rims wheels, stand splash plate and under panel cowls tank etc powder coating to keep cost down, and the rest of the scooter bodywork can then be re sprayed in the same Ral code to ensure a match. Staying close to Factory colours at the same time. There are a lot of Ral codes that are close to Innocenti Lechler colours, but has i have said not a spot on match. depends what you are aiming for and how fussy you are i suppose. If doing a full blown correct concours resto, then of course Lechler paint codes must be used. I can post the chips to you recorded delivery if it helps.
Regards Waddo.
waddo
Re: RAL Codes
Postby Toddy » Wed Dec 07, 2016 7:13 am
Thanks Guys , Dave i will speak to the lad who is after them tonight hoperfully and be in touch
Re: RAL Codes
Postby Big Al » Fri Dec 09, 2016 10:51 am
Lambretta Paints in Cheshire are a good source of original Lechler colours:
http://www.lambretta-paints.co.uk/shop/
They have supplied the correct colour for my Model D.
Big Al
Re: RAL Codes
Postby gp200ts1 » Thu Jan 05, 2023 7:25 pm
Does anyone know if ral do an equivalent to 8080 yellow ochre? I can refinish the seat loop with matched paint but would prefer to have the frame itself powder coated.
gp200ts1
Users browsing this forum: Google [Bot] and 69 guests
