Tyre Pressures
Tyre Pressures
Postby Dazza » Tue Jun 03, 2014 6:54 am
Trying to build up the ' Body of Knowledge'...
What are the reccomended tyre pressures for SIP tubeless or the like?
I know there isn't a definitive answer due to variables such as speed travelled and whether two up etc..but what is a ball park pressure?
Dazza
Re: Tyre Pressures
Postby drivera » Tue Jun 03, 2014 9:12 am
I always run 24psi front and 34 psi on the rear , that's with Conti Navigators on split rims with tubes , work ok for me :)
drivera
Re: Tyre Pressures
Postby HxPaul » Tue Jun 03, 2014 11:18 am
18psi front and 28psi rear with rider,34psi. with rider and passenger.Michelin s1's on standard split rims with inner tubes.
Re: Tyre Pressures
Postby Toddy » Tue Jun 03, 2014 12:05 pm
20 front 30-34 rear dependant on passenger/luggage/load , on tubless and splits
Re: Tyre Pressures
Postby mickyb » Tue Jun 03, 2014 1:07 pm
25 front, 35 rear, conti twist on tubeless
mickyb
Re: Tyre Pressures
Postby Rich Oswald » Tue Jun 03, 2014 3:04 pm
Toddy wrote:20 front 30-34 rear dependant on passenger/luggage/load , on tubless and splits
Same here Toddy :D
Users browsing this forum: No registered users and 85 guests
