Knowledge wrote:Torque wrench Paul? You're just showing off now, you and your fancy tools.
Just trying to get my head round the modified stud WT1 wont an ordinary stud have more thread area and bottom out the same but be stronger
Storkfoot wrote:............... My Dad, who fixed planes in the war, taught me something very similar which I still do to this day on hubs, gearbox endplate and loads of other things.Knowledge wrote:..... The factory recommendation on tightening the nuts was to get them all tightened down in a relevant order until they were all just biting, and then turn them all by a quarter turn (again in a pre-described order) and then go round again with another quarter turn again.
Post by Phil D » Mon Nov 21, 2016 11:03 pm
The photo is exactly what I had in mind but I guess I'll just have to trust your engineering expertise it just doesn't feel right because all I see is missing threads on the ends of the studs.
Just glad I run a low power engine!
Post by Knowledge » Tue Nov 22, 2016 1:54 pm
The best studs I found were Suzuki TS185 items. Proper quality.
Meanwhile, back at the coal face, I have made progress.
Some high winds closed the Orwell Bridge today, so I couldn't get to the office. With my laptop in the office, I'd decided to go down the workshop instead. They owe me a morning off, surely.
With the Three bond repairs cured, I put some air back into the cylinder. The leaks I had tackled with the Three bond were all good but I could hear that there was still air leaking from the cylinder. I used the stethoscope that came with my cheap blood pressure gauge to isolate where the hissing was coming from (surprisingly effective) and then put some bubble solution in the right place. Yes, a leak from an inaccessible place where the reed manifold had been welded to the barrel.
I decided that I could ease-out the reed block and put some epoxy glue inside the inlet manifold, but having got that nicely sealed up, I decided to tackle it from the outside. I was able to get the epoxy glue to run down a seam to where I suspected the leak was emanating and waited for it to cure. Even if the epoxy burns off, at least I know where the problem is located and I have an alternative solution to the leak.
To my delight, the test was very good and the engine looks fit to go back in again. However, as I sit here typing this, I wonder if I should have had the piston at BDC before starting the leak-down test? The air is entering the cylinder via the exhaust port.....
I need to check where the piston is sitting in the barrel, and perhaps repeat the test.
coaster wrote:[
Funnily enough, the torque wrench was invented for tightening aircraft engine big end cap bolts as mismatches in torque setting were causing catastrophic engine failures...or so I read somewhere.
Although owning 2 torque wrenches, I only use them on the flywheel and head studs, everything else is done by 'feel' using a similar method as mentioned above
Warkton Tornado No.1 wrote:I really hope those alloy nuts have been left out of the assembly as part of the process of elimination....
Post by Knowledge » Tue Nov 22, 2016 8:25 pm
The Ali nuts are still there. I have not had reason to suspect that they were the cause of the head issue. I am confident that the problem was loose barrel stands, rather than loose head nuts. Indeed, when I undid the head nuts, three of the studs came out with the Ali nuts still attached. As I said previously, the studs were not fully home in the casing, but they are now.
The nuts are ali and the casings are ali. There is ali at both ends. I am not about the replace the casing with ones made of steel in order to address an unfounded issue with the metal that the studs screw into. If the ali nuts are found to be at fault next time, then I will (and should) apologise to all the ali-nut doubters who have contributed to this thread ("thread" eh? Get it?)
Knowledge wrote:
Now I am sure some people will not want to contribute to this thread again until I dispose of the ali nuts, but I will check them this weekend and see if they can be blamed for the problem.
Knowledge wrote:
Does anyone anneal their cylinder head gaskets?
