Post by Stevepshipley » Sun Nov 20, 2016 3:12 pm
Just finished my restoration
viewtopic.php?f=19&t=4850
It's original flywheel etc and points/condenser and runs really nicely, but in this set up what acts as a regulator?
Just been playing round the block (not yet registered) and I seem to have blown the tail and dipped beam lights. My hazy memory thinks that one of the lights (speedo or the parking ligh) acts as a kind of soak for any overload. I may just have imagined this, so what causes/stops bulbs blowing under high revs.
cheers steve
Post by Stevepshipley » Tue Nov 22, 2016 12:15 am
Did you mean rectifier or regulator WT1?
I don't know what a rectifier does?
Cheers steve
12 volt speedo bulb so I'll see how it goes.
johnnyXS wrote:Just looked at your scoot on the other thread .
Santa has been early hasn't he![]()
The scoot hasn't got a battery fitted so it won't have been fitted with a rectifier or a regulator .
Your Stator lighting coils generate an AC voltage which feeds your AC bulbs and horn directly which is why your lights increase in intensity as your revs rise and dim into oblivion when at idle.
if you want to fit a battery you'll need to find somewhere to fit one . they are usually fitted on the non-carb side in front of the air tank .You'll need to fit a rectifier which rectifies your existing AC voltage into DC (direct current) voltage so that it can charge your battery and a Regulator which makes sure that the battery doesn't get overcharged . They are usually in a combined module for convenience but don't necessarily have to be .Naturally if you do this you will need to change all your bulbs to DC whether 6v or 12v and probably the horn as well
I would look for a Vespa regulator/regulator they are modern and easily obtainable and whilst you are there I'd advise anyone to fit a PX200 Vespa coil as well. much better than the lambretta jobbie.![]()
Am I allowed to say the word Ve**a ?![]()
HxPaul wrote:[
Never heard of ac or dc bulbs.You'll definitely have to change the horn.
HxPaul wrote:All scooter/motorcycle and car shops just sell bulbs,they dont specify wether their ac or dc.If your saying that ac and dc will work with both battery and non-battery systems,whats the point of having 2 different kinds?
Users browsing this forum: Charliescooter, Google [Bot] and 219 guests
