Series 2 - can you use GP panel clips?
Postby Covboy » Wed Nov 16, 2016 9:58 pm
Ok it seems like an odd question - but has anybody used GP panel clips on. S2 ....if so what modifications required???
Pics appreciated if possible
Re: Series 2 - can you use GP panel clips?
Postby gaz_powell » Wed Nov 16, 2016 10:44 pm
You can't use GP ones - you need the API ones and they are like rocking horse s+%t.
I built my S2 and wanted an uncluttered panel look so had f/b ones made without tubes/handles thinking I would just use GP and got the end and found not, I had to make some fortunately a kind mate lent me a set to make some - if i'd have made 10prs I could have sold them straight away
http://www.lambretta-images.com/archive ... p?pid=3497.
Although looking at it again it appears that the gp ones might bend!!! But memory tells me the couldn't, reason why I made some (the bottom ones)
Still think they look mint without handles - I removed all badges and replaced with vinyl for the smooth look.
Gaz
Postby Covboy » Wed Nov 16, 2016 11:14 pm
MM.. I think I'll buy a GP pair and bend them... Thanks gaz
Ps nice x19!
Postby gaz_powell » Wed Nov 16, 2016 11:29 pm
I keep meaning to have another go with GP but like many things...time!
Worth a try.
Good spot on the X1/9, original '78 1300 having some TLC for 2017
Got a good photo somewhere of my GP next to the X1/9 next to my Alfa GT - arguable Bertones three greatest designs.........
Postby Covboy » Wed Nov 16, 2016 11:38 pm
Gets some pics on next weeks show your ride theme ....!
Postby Digger » Thu Nov 17, 2016 5:45 pm
I had a go at bending some GP ones but I don't have much in the way of smithy's gear - they just about work but I wouldn't trust them on the road.
With a bit of patience and skill it can be done.
I do have a pair of API ones if someone wants to have a go at copying them. :idea:
Digger
Postby Covboy » Thu Nov 17, 2016 7:03 pm
Hi digger
Would you be able to photograph them if possible so I can see the difference please ?
...and if you had a GP set next to them for reference that would be even better!!!!
No rush whatsoever
Steve
Postby Digger » Thu Nov 17, 2016 9:19 pm
I'll do that and get some measurements too.
Digger
Postby carlos fandango » Fri Nov 18, 2016 1:13 am
Did it on my LD ,not to different to an S1/2 shape
carlos fandango
Postby Digger » Fri Nov 18, 2016 8:53 am
8-)
Digger
Postby gaz_powell » Fri Nov 18, 2016 9:24 pm
Nice one - we'll done on that....im wondering now why I took the time to bend new from scratch (which was a pain) instead of altering some GP ones!????
I'm gonna have a go at the gp ones soon......
Postby Covboy » Fri Nov 18, 2016 10:24 pm
