Grease gun ?
Grease gun ?
Postby mm man » Sun Nov 13, 2016 10:01 pm
What are people using on model ds ?
Are guns still available ? If so what am I looking for ? and from where ?
mm man
Re: Grease gun ?
Postby Knowledge » Sun Nov 13, 2016 10:53 pm
I don't have a D, but the world seems to be moving away from the traditional grease gun and towards tubes of grease that you insert in a dispenser like a silicone gun you would use to seal around the bath.
Like the D, I have never used one of these either.
Re: Grease gun ?
Postby ladsdad » Mon Nov 14, 2016 1:07 am
Hi
The type of grease nipples fitted to the model d is a,"slide on" type grease nipple... You can still buy the slide on adaptor to fit a regular grease gun from the likes of ebay, no problem. The nipples themselves might be a bit more of a challenge but should be available from suppliers that sell bulk fixings & fasteners... alternatively this type was also used until relatively recently on E.R.F trucks (r.i.p) so you could go down the h.g.v motor factor route & try your luck there.... in fact I came some in a box of assorted nipples at work only last week, so the're definitely still out there....
Regarding filling your grease gun, there's nothing to stop you filling your grease gun manually if you have a tub of grease to hand, the cartridge is only there to make a dirty job slightly less dirty....
Good luck Mark.
ladsdad
Re: Grease gun ?
Postby Tractorman » Mon Nov 14, 2016 10:14 am
Very true Mark but they also overcome the problem of people leaving the buckets of grease without the lid replaced and the grease being contaminated by grinding dust and other workshop dirt. Grease guns and various nipples, sorry USA I mean zerks, are easily obtained from agricultural outlets and the like.
Re: Grease gun ?
Postby jbcollier » Mon Nov 14, 2016 3:38 pm
The fittings are available from shaft drive specialists, probably elsewhere as well. Remember they are metric if you are trying to source them locally. You do not need a special grease gun. You can use a regular grease gun with a blunt, pointed tip, or a similar adapter:
https://www.amazon.ca/Lincoln-Lubricati ... B0002SR6XE
jbcollier
Re: Grease gun ?
Postby mm man » Mon Nov 14, 2016 10:57 pm
Thanks guys I now know what I am looking for which is of great help
The nipples were not a problem as I have more spare nipples than scaramanga it was knowing how to fill them and now it all makes sense
Cheers again for your help :)
mm man
Re: Grease gun ?
Postby missing lynx » Mon Nov 14, 2016 11:02 pm
machine mart do grease guns but the best place to get them from is a carboot sale
Re: Grease gun ?
Postby mm man » Sun Nov 20, 2016 10:34 am
Got one Similar to this ( only £2.95 delivered ) fits the nipple a treat
http://www.ebay.co.uk/itm/SLIDE-ON-GREA ... xyrP9RaWQU
Thanks again guys
mm man
Return to Pre 57
Users browsing this forum: No registered users and 30 guests
