Post by bluebob » Fri Nov 04, 2016 11:08 pm
does anyone know if standard type front dampers have a maximum working length.Reason I ask is when I extend a new set,before I reach the length I want the resistance in the damper disappears.so I,m thinking when fitted will it actually do any damping .I know my fork brackets are about 15mm higher than recommended but the damper loses suction/resistance before this point anyway.so will fitting them be a waste of time?
Unread postby bluebob » Tue Nov 08, 2016 5:31 pm
cheers warkton.was hoping someone made an oversize version but as that's not the case I will get the brackets moved .
Post by dickie » Tue Nov 08, 2016 6:10 pm
What's horrible about them?
Users browsing this forum: No registered users and 85 guests
