air leak
air leak
Postby dicko » Wed Nov 02, 2016 10:57 pm
Hi all I'm having a mare trying to find a air leak have had a leak coming up throuh the studs and coming out of the nuts at the head that one sorted. Next leak coming out by the jacking holes on the mag housing mag housing sourced that leak fixed but when put under pressure there's a small leak which I can't find ive used more fairy liquid my hands are getting soft. I put it under pressure its starts to drop very slowly but when I warm it up with a heat gun it doesn't drop? So could I run with a small leak. Yes or no
dicko
Re: air leak
Postby HxPaul » Wed Nov 02, 2016 11:11 pm
Check your leakdown equipment,it may be leaking air.
Re: air leak
Postby dicko » Wed Nov 02, 2016 11:27 pm
I've checked the tube at both ends no leak
dicko
Re: air leak
Postby HxPaul » Wed Nov 02, 2016 11:59 pm
I use a foot pump and a bmx inner tube to do a leakdown test.At first there was an air leak and I couldn't find were it was leaking from.Eventually I found the leak,it was leaking from the pump itself,not the engine or the inner tube.I dont know what type of pump you use,but it may be worth checking it.
Re: air leak
Postby dscscotty » Thu Nov 03, 2016 12:09 am
Its not ideal, however I've seen a few that drop the gauge needle very slowly and they've been fine, check your mag and drive seal, if you no sign of leaks from gasket faces?
Re: air leak
Postby bazza3004 » Thu Nov 03, 2016 3:29 pm
How long does it take for pressure to drop. Built an engine some time back that did the same but couldnt locate any leaks. The engine ran fine all year.
bazza3004
Re: air leak
Postby dicko » Thu Nov 03, 2016 8:48 pm
Hi lads im using one of those hand held pumps with a dial im pumping it up to 140 it takes approximately 50 seconds to drop down to 135 it could be the dial? Im going to go back and try the inner tube and see if that works but it will be tomorrow night before I get to try it will let you know what happens
dicko
