by Raveydavey » Sat Oct 29, 2016 4:07 pm
Recent issue when starting, after about 30 seconds or so lots of exhaust smoke, clears after about a mile or so of riding. I suspect worn rings might have something to do with it, compression not great. I'm planning a rebore in a couple of weeks so if thats the reason, it should go away. I'm just hoping it's not the drive side oil seal, but if it was it wouldn't stop smoking once its warm...would it?
Raveydavey
by Digger » Sat Oct 29, 2016 5:28 pm
All mine smoke when cold.
Drive side oil seal smoke is white, smells 'orrible and is like a smoke screen - nothing like 2-stroke smoke.
Digger
by kennystag » Wed Nov 02, 2016 9:11 am
Hi If the smoke clears why bother stripping the engine, most lammys do smoke anyway.
Stag
Skye
kennystag
by coaster » Wed Nov 02, 2016 1:34 pm
kennystag wrote:Hi If the smoke clears why bother stripping the engine, most lammys do smoke anyway.
Stag
Skye
Good point and the type of oil used and the ration will have an effect too, always look for 'low ash'
by Raveydavey » Wed Nov 02, 2016 10:07 pm
Stripped the top end. Turned out the barrel was mince. Big gouge where plating had worn away by the exhaust port. It's a proper mess. Amazing it even ran.
It never smoked before so I knew something was up. Compression seemed to be getting worse. Oh well time for a new kit.
Raveydavey
by HxPaul » Wed Nov 02, 2016 10:11 pm
Raveydavey wrote:Stripped the top end. Turned out the barrel was mince. Big gouge where plating had worn away by the exhaust port. It's a proper mess. Amazing it even ran.
Langcourts can repair and re-plate the barrel.
by Raveydavey » Wed Nov 02, 2016 10:25 pm
It would need at least 1mm boring out, to 71 mm or even 72mm and it'd need a new head. It's recessed. New piston and replated. If I'm going that far I might as well have some porting done. Love the idea but big bucks.
Raveydavey
by dickie » Wed Nov 02, 2016 10:41 pm
Steel liner and some porting?
You can keep piston size down to 70mm and no new head.
by HxPaul » Wed Nov 02, 2016 11:12 pm
Raveydavey wrote:It would need at least 1mm boring out, to 71 mm or even 72mm and it'd need a new head. It's recessed. New piston and replated. If I'm going that far I might as well have some porting done. Love the idea but big bucks.
They wont bore it out until its clean,they will weld up the fault and then bore it.
by kennystag » Thu Nov 03, 2016 8:34 am
Very Strange how it cleared after a run with that much damage. Good luck with the rebuild.
Stag
kennystag
by HxPaul » Thu Nov 03, 2016 10:05 am
HxPaul wrote:Raveydavey wrote:It would need at least 1mm boring out, to 71 mm or even 72mm and it'd need a new head. It's recessed. New piston and replated. If I'm going that far I might as well have some porting done. Love the idea but big bucks.
They repair any damage by welding,then bore it to the original size (you wil have to supply a piston of the original size) and then re-plate the cylinder and hone it to the right size.
by Nudger » Thu Nov 03, 2016 12:34 pm
Good grief - at least the old 'gal got you back from Euro Lambretta & Shipston Dave.
Nudger
by Raveydavey » Fri Nov 04, 2016 6:04 pm
Damn right Nigel! She has a 'never surrender' attitude
. If I get a chance ill post a picture to show just how bad it was. And she kept on going, just.
Raveydavey
Users browsing this forum: Google [Bot] and 95 guests
