Indicators
Indicators
Postby Norfolk » Fri Aug 08, 2014 12:38 pm
Hi Guys, Has anyone fitted indicators to a series 3. I had thought of LED bulbs powered by a battery.
Any info would be appreciated.
Norfolk
Re: Indicators
Postby coaster » Fri Aug 08, 2014 2:10 pm
A few have done this, Angry Bloke on here has a particularly neat set up on his LiS 8-)
Re: Indicators
Postby Angry Bloke » Fri Aug 08, 2014 3:36 pm
^ Thanks Colin :D
Mine are fitted in the rear lens and on the front mudguard
Here my wiring diagram courtesy of Byron ( Lambretta Rehab ) on here
Angry Bloke
Re: Indicators
Postby Toddy » Fri Aug 08, 2014 4:27 pm
Angry Bloke wrote:^ Thanks Colin :D
Nice job mate :D
Re: Indicators
Postby Rich Oswald » Fri Aug 08, 2014 6:58 pm
Very neat :D
Re: Indicators
Postby Knowledge » Fri Aug 08, 2014 7:56 pm
I wrote about fitting indicators in a recent Oily Rag article in Jetset. There are LED indicator kits on eBay which include the special LED compatible relay.
I'm pleased with my indicators.
Re: Indicators
Postby carlos fandango » Fri Aug 08, 2014 10:20 pm
Heres mine , i made them myself :)
If you use LEDs make sure you get an "electronic" relay.
carlos fandango
Re: Indicators
Postby Norfolk » Sun Aug 10, 2014 7:59 pm
Thanks Guys for the info. Anybody know which addition of Jetset Knowledge wrote his article on indicators.
many thanks
Norfolk
Re: Indicators
Postby Knowledge » Sun Aug 10, 2014 8:08 pm
Edition 188. There is a white S1 street racer on the front.
Re: Indicators
Postby MK Monty » Sun Aug 10, 2014 10:07 pm
What are you guys using for switches on series 3. I have a special that I have thought about changing to use a LI type but I will have to change the throttle housing., disc brake mount.
Just added these to the rear of my series 1 as I was concerned a leg down at lights would block the view of the ones at the front
They are LED and also have stop and tail lights, brighter than they look due to the flash
These were on the old forum sorry its not a series 3
MK Monty
Re: Indicators
Postby grandpa » Mon Aug 11, 2014 12:04 pm
Hi Norfolk,
I used conventional 23 watt motorcycle indicators and mechanical relay( Bimetal strip). Note as I understand if you cant see indicators from riding position you will need a warning LED or buzzer.Carlos's neat solution would seem to bypass the the need for a warning light. A stainless steel bracket fits under light switch which means the switch is raised up out of its normal position a strip of black plastic from an aerosol cap covers the gap. I have led warning light in speedo Some one on old forum had modified Honda moped indicator switch which looked very professional.
I have used smaller switch and smaller stainless steel bracket on n0 2 scoot as shown with cycle inner tube to water proof it
Both scoots are wassel DC with battery .I assume you are going to charge battery from mains ( with long lead :D) two conventional indicator bulbs would draw 3.8 amps but only infrequently
The front indicators have longer stems than rear and cost about £6 a pair 3 pin relay about £6.A 12v motor cycle battery about £15 some used house alarm batteries to good effect.
Hope this helps
Grandpa
grandpa
Re: Indicators
Postby Knowledge » Mon Aug 11, 2014 12:53 pm
Here are my indicators fitted: this missing bit from Oily Rag in Jetset 188.
Quite discrete
Re: Indicators
Postby terryj » Mon Aug 11, 2014 3:19 pm
i brought a switch from beedspeed straight replacement for li ser 3 switch just had to add an ignition switch for lights off
http://beedspeed.com/lambretta-light-in ... -9018.html
terryj
Re: Indicators
Postby MK Monty » Mon Aug 11, 2014 4:48 pm
Knowledge wrote:Here are my indicators fitted: this missing bit from Oily Rag in Jetset 188.
Quite discrete
And the Cree headlights Lamps? do they conform to dip and Full beam? Im using a 3 w one in aluminium rear light and its VERY bright
MK Monty
Re: Indicators
Postby Knowledge » Mon Aug 11, 2014 7:09 pm
Well, the scooter gets through the MoT each year, though I understand that I am avoiding answering your question.
One year it will be failed, or spotted by the police, but until then, I think these are the best lights you can fit to a Lambretta. LOADS of light.
One lamp is 9w and the other is 27w. I use the 9w for dip, and both for high beam. Sometimes, the reflection off road signs at full beam is too much, and I have to switch to dip. Lovely.
Re: Indicators
Postby MK Monty » Mon Aug 11, 2014 7:19 pm
:mrgreen: You have me thinking now about my pathfinder, I used the multi LED lamps and they are crap, so stayed with the tungsten lamp. I have a 3 led cree that I may try in the back of the reflector. Thanks
MK Monty
Re: Indicators
Postby eddie15b » Mon Aug 11, 2014 8:57 pm
i used motrax tinycators but they are now hard to get a hold of so these would probably be your best bet now
http://www.ebay.co.uk/itm/4-x-Chrome-Un ... 3f39a96f34
they are so cheap its silly
youll also need one of these indicator packs
http://www.vehicle-wiring-products.eu/V ... cators.php
but when you order it make sure you tell them that its for an led type indicator as the flasher relay will be different
included in their kit is a pretty good instruction leaflet on how to wire it all up
its pretty simple really
after that its just a case of where you want to site them below is how i set mine up
sadly SR dont do the old original indian rear indicator stems any more (sold out) but you can
just use an L shaped bracket from b&q to hold it onto the back of the number plate
i also got a hold of an old li150 switch unit and housing and then rewired it to have the bottom
rocker switch opperate the indicators and i also got the 3 pin indicator relay from VWP so
that the spare connector could be run up to a led light in the speedo (LHS one) that way
youve got your idiot light covered for your mot test
the speedo comes apart easily and you just drill a 5mm hole in the plastic faceplate and superglue it in
eddie15b
Re: Indicators
Postby peejay » Mon Aug 11, 2014 11:23 pm
hi Monty
could you give me more details on these please :)
Re: Indicators
Postby MK Monty » Tue Aug 12, 2014 7:25 am
these are the black ones
http://www.ebay.co.uk/itm/Black-Motorcy ... 5afd8b1675
They do a plastic chrome ones as well. They needed the bracket cutting off and I had problems wiring them to flash both top and bottom ambers at the same time. I had to install a small diode to make sure that one flashing did not flash the stop LEDS. They are designed to fit above or under a number plate and they worked fine like that but I was going for the Bieme look.
I had a set of the royal enamel ones but the plastic lenses looked like wine gums glued on and looked an insipid pink colour, they fell to bits after a couple of months
MK Monty
Re: Indicators
Postby CHRIS in MARGATE » Tue Aug 12, 2014 8:14 am
I want to do this soon. Can somebody assure me of the correct legal requirements re: lens colour back and front and distance between left and right?
Users browsing this forum: No registered users and 96 guests
