How 3D printing technology is changing Lambretta tuning part development...
http://www.scooterlab.uk/birth-of-a-cylinder-kit-ss-250-feature/
Digger wrote:So what happened to the 305?
Sticky wrote:So here's an interesting question. Given the choice of:
A: a bridged port, big carb, expansion chamber, 50hp but quite rideable and progressive engine
B. a single-port, small carb, expansion/box making 35-40hp with more torque and longetivity in mind
which would you really spend money on if the price was not much different?
This is a serious question because I am aware that a lot of people would want full-fat rather than the more sensible version. It's often a question of want rather than need
Strummer10 wrote:
My real worry on a Lambretta has always been with all that power manufacturer's are kindly giving us low/top end, and although we use high performance bearings and crankshafts in the build......the 'weak link' is still in my opinion the layshaft which 'might' shear under torque or put unnecessary forces through it so my question is "is there not any thought being processed into thickening the layshafts and thus increasing them along with cone size to the hub and maybe a secondary 'fail safe' measure to keep the hub against the engine if a layshaft did ever shear"..........playing devils advocate there must be others out there thinking the same thing and many now riding increased powered lambrettas may well be using 50 year old layshafts...........
Is there anyway SLUK or scootering could engage a materials design engineer to do a test on new layshaft versus old layshaft 'pro's and cons' to see what this reaps....again only a thought ?
Users browsing this forum: No registered users and 47 guests
