30mm oko
30mm oko
Postby philcasino1973 » Thu Aug 07, 2014 7:32 pm
have rec ently been bought/given a gp200 with 200 rapido barrell etc....its running a 30mm oko carb open mouthed
have bought a remote filter kit with cone filter ...what do i need to do with jetting? and who sells parts for these carbs as no experience with them
thanks
phil
philcasino1973
Re: 30mm oko
Postby coaster » Thu Aug 07, 2014 9:06 pm
OKO is the name of the PWK copy from ScootRs who also sells jets and needles. You can also buy jets and needles from Scooter Centre Colne in Germany http://www.bgm-tuning.com/product-categ ... arburator/.
Re: 30mm oko
Postby drivera » Fri Aug 08, 2014 12:56 pm
Splat shop also sell needles / jets etc and they in the UK :)
drivera
Re: 30mm oko
Postby Storkfoot » Fri Aug 08, 2014 2:23 pm
Also, I can confirm from my experience a few years back that the non-Keihin needles are not the same as genuine Keihin regardless of what is stamped on it. This makes them difficult to jet without going on a dyno.
Irrespective of whether they are good carbs worth persevering with, you may well have to re-jet for that filter. I have never tried one of those filters but they look very restrictive and have you considered how you will fit it?
Re: 30mm oko
Postby philcasino1973 » Fri Aug 08, 2014 6:29 pm
its the one with the malossi filter and rubber elbow does fit on ok and sits where airbox used to be
did put it on and ran it for a couple of short local runs round haydock/n-le-willows ......stopped to see a mate when i went to go again it wouldnt start
i had made the schoolboy error of nipping out with no plug spanner or spare plug :mrgreen: :mrgreen: :mrgreen: :mrgreen:
when i got it home in the van i took plug out it was thick with oil! wiped it and it started
so then was panicking thinking crank oil seal had gone! not showing any other symptons tho and has been fine since albeit with new plug and back to open carb
phil
philcasino1973
Re: 30mm oko
Postby Storkfoot » Fri Aug 08, 2014 7:45 pm
Sounds like the filter, which by its nature restricts air to a degree, has made it too rich.
If you want to keep a filter, I'd recommend taking it to PSL in Kirkby. Pete has a dyno and charges a very reasonable price, IMO, to check the air/fuel ratio and jet the carb. I'd phone him first to see whether he has Keihin jets and needles though as these (poorly IMO) remade Keihin carbs are not everyone's cup of tea.
I know previous posters on this thread will disagree though :D
Re: 30mm oko
Postby coaster » Fri Aug 08, 2014 9:14 pm
Storkfoot wrote:................I know previous posters on this thread will disagree though :D
Oi, I resemble that remark :oops: You know it's because I like a challengs ;)
colin
Re: 30mm oko
Postby CHRIS in MARGATE » Sun Aug 10, 2014 9:39 pm
Cannot run mine with a filter on. Won't restart.
Perfect without filter.
Re: 30mm oko
Postby rossclark » Sun Aug 10, 2014 9:50 pm
Check the types of jets in your carb before ordering as I believe some of the scootrs ones have an oddball jet config which is different from the standard PWK type
Re: 30mm oko
Postby CHRIS in MARGATE » Mon Aug 11, 2014 6:25 am
Definitely 2 different main jet types easily recognised because 1 is long and the other short.
Re: 30mm oko
Postby philcasino1973 » Mon Aug 11, 2014 9:04 pm
thanks lads for all your help ..will strip down and have a look at it an d report back :mrgreen: :mrgreen:
gonna contact psl at kirkby as storkfoot recommends only 10 mile away from me so maybe a run on his dyno for piece of mind
if allelse fails could be new carb time ...will be back on for your recommends
taaaaa
phil
philcasino1973
Return to Carburettors
Users browsing this forum: Google [Bot] and 62 guests
