by grandpa » Sun Oct 23, 2016 3:40 pm
Hi Chaps,
I am after a 200 probably a Spaniard but if I did look at an Indian GP 200 is there any way of determining whether the engine is a true 200 rather than a small block
with a 200 kit without dismantling it? I.E any markings or extra strengthening ribs cut outs on fins etc
Thanks,
Grandpa
grandpa
by MickYork » Sun Oct 23, 2016 3:51 pm
Distance across cylinder nuts........
Inlet manifold studs........
Engine number.....
by Rich Oswald » Sun Oct 23, 2016 4:19 pm
MickYork wrote:Distance across cylinder nuts........
Engine number.....
Agree with the first two but wouldn't rely on the engine numbers,
by grandpa » Sun Oct 23, 2016 4:51 pm
Hi Chaps,
Thanks chaps ,but I would have to take cylinder cowl off to see cylinder nuts .I might be able to measure the inlet manifold studs on my gp 150 though and compare. I assume the distance across studs on a 200 is greater than a 150 but so would a 200 kit . This would be an Indian gp200 I might look at.
Thanks for your good ideas
Grandpa
grandpa
by Adam_Winstone » Sun Oct 23, 2016 5:33 pm
I'm not sure that any of the SIL 150 casings had the same reinforcement webs on the mag side engine mount, whereas the late/common 200 casings do.
by grandpa » Mon Oct 24, 2016 4:45 pm
Hi Adam,
Thank you I will look into the webs on mag side.However,I have now received a reply to an inquiry about a Spanish Jet 200 with matching numbers and plan to look at it on Friday
Regards,
Grandpa
grandpa
Users browsing this forum: Baidu [Spider] and 70 guests
