li 125 series 3
li 125 series 3
Postby waynekemp » Tue Oct 11, 2016 8:24 pm
i am having problem with clutch i have engine rebuilt when i pull clutch lever on engine when in gear it will not disengage unable to work out engine is on bench
waynekemp
Re: li 125 series 3
Postby HxPaul » Tue Oct 11, 2016 8:39 pm
If your trying to depress the clutch by using the lever on top of the engine,you cant do it by hand.You need to use an open ended spanner on the lever,or connect it up using the cable and handlebar lever.
Re: li 125 series 3
Postby waynekemp » Tue Oct 11, 2016 8:48 pm
hi ive tried the spanner on the lever but it wont disengage do you think the clutch hasnt been put back properly
waynekemp
Re: li 125 series 3
Postby waynekemp » Tue Oct 11, 2016 9:15 pm
could the plates be stuck together
waynekemp
Re: li 125 series 3
Postby kennystag » Wed Oct 12, 2016 8:41 am
You will have to strip it down to check it out.
Stag
kennystag
Re: li 125 series 3
Postby missing lynx » Wed Oct 12, 2016 11:36 am
did it compress when you were putting it together using the clutch compressor? also is the arm solid or does it move but have no affect on the clutch?
Re: li 125 series 3
Postby EddieStone » Wed Oct 12, 2016 1:38 pm
There's a little clutch plunger that can drop off the actuating lever when you put the cases together. If there's no resistance when you pull the lever, then that could be the problem. Irritating when it happens. It looks like this:
EddieStone
Re: li 125 series 3
Postby HxPaul » Wed Oct 12, 2016 2:30 pm
EddieStone wrote:There's a little clutch plunger that can drop off the actuating lever when you put the cases together. If there's no resistance when you pull the lever, then that could be the problem. Irritating when it happens. It looks like this:
Only on GP's though.
Re: li 125 series 3
Postby waynekemp » Wed Oct 12, 2016 3:19 pm
i have found problem i made clutch compressor and took plates apart guess what plates rusted together i expected the man who rebuilt engine to put new plates .trust eh
waynekemp
Re: li 125 series 3
Postby missing lynx » Wed Oct 12, 2016 11:07 pm
Rusted together ? they should be metal,cork, metal, cork no metal surfaces should be together
Users browsing this forum: Baidu [Spider] and 65 guests
