Lambr62 wrote:Is it necessary to re-torque head after 100 miles? Wanted a second opinion as it mentions this in the running in instructions. Thanks for any advice.
burnside wrote:Surely after fitting a new kit it is sensible to check everything over after the 1st 100 miles? Re-torque the head, check exhaust fitting at joins and manifold, etc.? Even if everything is fine it is worth it for piece of mind.
Warkton Tornado No.1 wrote:A
At the risk of repeating what I, along with others, have said previously, adding extra oil weakens the mixture.....
Post by johnnyXS » Wed Oct 12, 2016 12:29 pm
theres no getting away from it it is a faff to have to remove the engine cowling to retorque the nuts but if it were me I'd run a new engine for a few miles to thoroughly warm the engine up and let it completely cool down again several times then retorque the head and then put the cowl and other stuff back on.
Theres no way a new engine is going to overheat without a cowl in this weather whilst its being carefully run in with extra oil mix 4% maybe and avoiding high revs and heavy loading.
Post by johnnyXS » Wed Oct 12, 2016 4:34 pm
A
its not that simple![]()
yes it does .......but that is not necessarily any reason to add less oil to your petrol oil mix ratio during running in period.
Every engine needs to be assessed individually . A aluminium race engine is going to have vastly different lubrication and performance requirements to a standard road going cast iron engine used for commuting.
The correct oil /petrol mix % ratio depends on lots of things including the carburettor used, the type of oil , altitude, state of tune, type of use , etc etc
Provided due care and attention is given to the timing and fuel mixture at all throttle positions and running in method there should be no problems with seizing , blown pistons or other catastrophic engine failure
