Stepped Stud - Stator Bolt?
Postby NorthernJordan » Fri Oct 07, 2016 11:39 am
Hi All,
I've had a few issues recently with bolts coming loose on the stator plate, and stripping the threads in the casing.
I'm thinking a stepped stud would be a good repair, as there would be less screwing in/out of aluminium.
Can I use a M8 to M6 stud? I can get these made at work and have the taps to do the job.
Jordan
NorthernJordan
Re: Stepped Stud - Stator Bolt?
Postby Knowledge » Fri Oct 07, 2016 12:16 pm
M8 sounds a bit too chunky, as the thickness of the engine casing at that point is a bit narrow and gets narrower behind the gasket face.
I would have thought that an M7/M6 stepped stud would be better, and no harder to manufacture.
Postby Warkton Tornado No.1 » Fri Oct 07, 2016 12:22 pm
The holes do tend to get ‘baggy’ in that area but rarely do they need little more than a thorough clean out & fresh M6 studs securing with a good thread locker. Beware of hydraulic lock, though.
Tapping M6 to M8 in the casting will work but there is not a lot of meat remaining around the holes & the casting can very easily crack. You can buy double ended M8 to M6 conversion studs but I wouldn’t choose them.
If you have access to engineering supplies, the better solution in alloy is to tap & fit an M6 thread insert such as Helicoil.
Many engineering firms fit these from the outset of making an alloy part, not just as a fix.
Postby NorthernJordan » Fri Oct 07, 2016 12:27 pm
I'm going to go for the M7/M6 stepped studs. I'm really doubting there is enough meat there for an M8. Everything is massive at work so it all get a bit limited when you go small!
I've ordered the M7 tap and will order studs now.
NorthernJordan
Postby drivera » Fri Oct 07, 2016 12:37 pm
As Warkton says why not try a helicoil , you can pick up kits from unithread for not much cash and once you have the steel thread inserted it wont wear out if you keep inserting/taking out the studs ?
drivera
Postby NorthernJordan » Fri Oct 07, 2016 12:44 pm
Once the studs are in, you don't have to remove/insert them, you just tighten a nut and washer up.
I'm not a big fan of helicoils either...
NorthernJordan
Postby Warkton Tornado No.1 » Fri Oct 07, 2016 4:38 pm
Post by NorthernJordan » Fri Oct 07, 2016 12:44 pm
Presumably you’ll just be replacing three studs & will continue using M6 socket screws/bolts to hold the stator in place. That is, unless there’s room behind the flywheel for nyloc nuts & washers...
Those particular holes are the three most subject to wear, but I’m sure you have it all figured out. ;)
Postby xenia1 » Sun Oct 09, 2016 5:48 pm
The helicoil is by far the better option, tap them out larger and after a while you'll have the same problem. Steel to steel wont wear like steel to alloy..
xenia1
Postby steve t » Sun Oct 09, 2016 7:26 pm
Helicoil is the way To go got me out out of the sh@t loads of times in the last 25 years not just lammies I know some people don't like but I think there ok and not badly priced plenty on ebay
steve t
Postby Knowledge » Mon Oct 10, 2016 4:42 pm
I must admit that my thread stripped, so I drilled it deeper and re-tapped it. It is now secured with a very long bolt, but it works.
I only remembered this at the weekend when I was testing some stators I had built.
Postby Warkton Tornado No.1 » Mon Oct 10, 2016 5:36 pm
Post by Knowledge » Mon Oct 10, 2016 4:42 pm
I think many of us have done something similar. I have used longer, M6 studs on occasion. I have even Helicoiled the end plate stud holes ‘down’ to M6 (same pitch as M7) so that I could use much higher grade socket fasteners as I was struggling to find decent M7 nuts @ some point years ago :idea: :!:
However, with the benefit of technology/engineering becoming much more accessible within the realms of DIY, I reason that advice given by the majority of us is our best advice, often with the benefit of hindsight.
There are ‘get-you-home’ bodges & there are ‘best-engineering-solutions’ ;)
Unfortunately, the choice often comes down to cost..... :roll:
Postby NorthernJordan » Thu Oct 13, 2016 4:27 pm
Well I've gone with stepped studs and nuts... We'll see how I get on!
NorthernJordan
