hydraulic master cylinder seals
Postby gaz_powell » Mon Oct 10, 2016 5:28 pm
After a bit of research for a need, if anyone uses the older Yam RD type MS over the widely used nissin type, the seals are the same as those sold by beedspeed for a fiver.
most places will only sell a full kit with piston, spring, 2x seals and the lever gator for 20 quid up.
Might be helpful for someone
Re: hydraulic master cylinder seals
Postby piskie » Thu Oct 13, 2016 8:18 pm
I think chiggy at lambretta up grades maybe able to help or warren shaw at shaw fire
piskie
Postby gaz_powell » Thu Oct 13, 2016 8:28 pm
Cheers Andy - i'm all sorted, as was an RD one I started at the bike shops, I was struggling for just seals then found out they are the same as the nissin ones which are easily available.
Gaz
