Scouse Scooterboy wrote:After a full restoration job on my S2, I was not impressed with the original drum brakes at all. The front did practically nothing, and the rear did a little better (I'd say 1/2 as efective as my Vespa PX). But now after getting a good few hundred miles on the scoot, the back brake is as useless as the front. There's practically no stopping power at all. Coming to a stop at a set of lights on a slight downhill doing about 20 mph I had to put my foot down, both brakes would not stop the scoot even at that speed! I know the drum brakes are not the best, but surely they should be performing better than this? Any advice greatly appreciated...
MK Monty wrote:First thing I would do is whip the rear drum off. Worth doing if only to prove your rear oil seal has not dropped oil on you shoes. By now you will have whiteness wear on the shoes. I would be surprised if you have even contact on the shoes. I found I was only using a 1/2 inch wide strip round the shoe and even then only on just over half of each shoe. Have a go at the high spots that are in contact to get more of the shoe in contact. A shoe trimmer is the best way but sand paper or a rasp type file may get the bulk off. I have in the past had to remove the steel pad on the cam end and file the end of the shoes as one was hard on with the other being unused. I'm afraid the quality of new shoes are not as good as the old ones so if you had a set that came with the bike I would be digging them out the scrap box. I have an outboard disk on one of mine but my series 1 standard front drum is not far away. The rear looses grip with the road and locks up if I stomp on it so I use the front most of the time with the rear if I need it. They can work very well.
Users browsing this forum: Baidu [Spider] and 61 guests
